Sponsored by: Auxito
Check engine light
Old Mar 30, 2008 | 08:19 PM
namdorf's Avatar
namdorf
Check engine light
I have a 1999 F-150 4x4 with a 4.6 automatic. The check engine light keeps coming back on, I have the auto parts reset it. It shows a code for Not enough Air Flow to the EGR. we changed the EGR and cleaned the manifold the best we could where it bolts on. Any thoughts! Light seems to come back on when it is wet or damp outside or alot of moisture in the air.......?
Old Mar 30, 2008 | 08:21 PM
LxMan1's Avatar
LxMan1
Usually it is a bad DPFE sensor (EGR sensor, not the valve itself).
Old Mar 30, 2008 | 08:27 PM
namdorf's Avatar
namdorf
Check engine light
Where is the sensor Located? Any idea or pics? Thanks Tim
Old Mar 31, 2008 | 12:12 AM
LxMan1's Avatar
LxMan1
It is a rectangular box with a plug on it and two small hoses that run to the EGR tube coming up from the exhaust to the valve.
Old Mar 31, 2008 | 04:22 PM
namdorf's Avatar
namdorf
Smile Check Engine light
Found the sensor underneath the throttle body( or what ever they call them on the Fords)cover, going to get a new one Thuraday when I'm off and see if this helps!
Thanks
Old Mar 31, 2008 | 06:40 PM
blue2golf's Avatar
blue2golf
Thanks
I've got the same problem. I also changed out the valve, but no luck. I've thought about changing the downstream 02 sensor, but now I'm interested in seeing how things turn out with your truck. Good luck.
Old Apr 1, 2008 | 07:22 AM
projectSHO89's Avatar
projectSHO89
Before spending another penny, read the thread from a couple of days ago in the Expy/Gator forum (same engine and system, you know).
Should be this one: https://www.ford-trucks.com/forums/7...l?nojs=1#links
Steve
Old Apr 1, 2008 | 10:48 AM
KingRanchMan02's Avatar
KingRanchMan02
Good advice Steve!
Old Apr 2, 2008 | 06:50 AM
projectSHO89
Dang, I wish they'd judiciously use stickied posts here. Gets old repeating the same thing over and over....
Sigh...
Old Apr 2, 2008 | 08:40 AM
Joe Finn's Avatar
Joe Finn
If the DPFE doesn't fix it, the EGR ports in the throttle body need to be cleaned.
davenpt
2004 - 2008 F150
21
Jul 7, 2014 01:33 PM
The Swamp
1997 - 2003 F150
Jan 8, 2012 09:37 PM
Eric1997f150
1997 - 2003 F150
Oct 10, 2006 08:03 PM
code_red
1997 - 2003 F150
Oct 25, 2005 04:58 PM
caperail
General Automotive Discussion
May 13, 2005 10:28 AM
