obd
Old Mar 30, 2008 | 07:48 AM
deezel's Avatar
deezel
obd
working on a 95 super duty w/7.3.check engine light on and o.d. light flashing.is this vehicle obd 1 or 2.thanks for any replies.
Old Mar 30, 2008 | 07:58 AM
Cuda_jim's Avatar
Cuda_jim
It may have both OBD connectors. OBD2 is under the dash, OBD1 is under the hood. It's a crap shoot as whether your trucks PCM has been re-flashed to the newer one.
If you are looking to pull codes for the flashing OD lite I'm pretty sure that OBD1 will not give out the codes. That's usually a transmission fault.
The CEL will have codes with both OBD's.....you have nothing to lose by plugging into either port to try an pull codes. Nothing bad will happen. Keep us informed.
Collision
31
Apr 9, 2025 10:22 PM
johnanderson
15
Feb 9, 2023 08:20 PM
Powerstoke73
Nov 7, 2014 12:48 PM
gbentinc
Oct 9, 2013 10:15 AM
wickymustang
Electrical Systems/Wiring
Sep 12, 2005 04:57 PM
