roller cams?
Old Mar 29, 2008 | 11:24 PM
Richharr's Avatar
Richharr
roller cams?
E3AE 6015 BA1 Cylinder block originally designed for full size car 1983 model year.
3L30 Cast on November 30th, 1983, appropriate for 1984 model year.
this is my 351w, I need to know how to tell if it has roller cams so I can order the right distributor gear
Old Mar 30, 2008 | 12:08 AM
Chuck_Sloggett's Avatar
Chuck_Sloggett
I don't think the roller cam engines came out until later. (85 or 86) -- Chuck
Old Mar 30, 2008 | 12:21 AM
Richharr's Avatar
Richharr
cool, I was a little confused because the engine is from an 86 f250
Old Mar 30, 2008 | 05:50 AM
5851a's Avatar
5851a
Someone here should have the casting # but I think the 351W blocks didn't get a roller cam till around 1994.
Old Mar 30, 2008 | 10:39 AM
Conanski's Avatar
Conanski
Correct.. the 351 didn't get a roller until 1994. However.. its still possible to put a roller cam in this motor, if it's not all original somebody could have swapped one in. It would be pretty obvious with the intake off, the lifter valley would have a spider assembly in it or the lifter pairs would have link bars on them.
Old Mar 30, 2008 | 01:39 PM
Beanscoot's Avatar
Beanscoot
If you are searching for a roller cam 351W engine, it must have a casting number beginning with F4TE (1994 or late 93 and up). Even some of those have a flat tappet cam, but will readily accept the roller cam, lifters and hardware from a 302 or 351.
Old Mar 30, 2008 | 02:13 PM
Richharr's Avatar
Richharr
just making sure of what I have
Big_Blue83
27
Jun 20, 2018 05:50 PM
black460
Oct 5, 2004 08:39 PM
Ford Truck Racer
Jun 7, 2004 06:06 PM
DannyP
Dec 21, 2003 12:42 AM
dbc
May 4, 2003 10:53 PM
