ts chip with 18k
Old Mar 29, 2008 | 09:32 PM
wmiller's Avatar
wmiller
ts chip with 18k
Is there any reason I cant run the 2? Driving today and pulling about 10k fealt great and egt only hit 900* pulling big hill on 75hp setting
Old Mar 29, 2008 | 09:54 PM
JethroF250's Avatar
JethroF250
hey wes. the only thing i can think of is mybe too much pressure on injectors. or timing is too advanced. idk. i ran joes chip at the strip and my truck ran fine
Old Mar 29, 2008 | 10:03 PM
wmiller's Avatar
wmiller
my thinking is it should be fine because all the 18k does is bump injector pressor. If the combo was making to high of pressure it would throw CEL. Just wanted to make sure it isn't doing anything goofy.
Still wanta race? MY shift points are 100 times better. On the high setting you dont even feel the shift
Old Mar 30, 2008 | 06:47 AM
JethroF250's Avatar
JethroF250
i'll pass. that makes sense it should throw the cel if pressure is too high. hey how much beatin should i need to do to get my rear wheel off. its solid
Old Mar 30, 2008 | 08:28 AM
c00nhunterjoe's Avatar
c00nhunterjoe
is your 900* pre or post turbo....?
and what do you mean the wheel is solid?
Old Mar 30, 2008 | 02:08 PM
JethroF250's Avatar
JethroF250
as in it was stuck on the center part of the axel. i took a 2x4 and a sledge hammer and beat it from the inside out. both sides were like that
Old Mar 30, 2008 | 02:28 PM
c00nhunterjoe
must have been a long time since you rotated last
Old Mar 30, 2008 | 03:04 PM
wmiller's Avatar
wmiller
that was a pre egt temp. I just switched from post last week.
Old Mar 30, 2008 | 06:47 PM
JethroF250's Avatar
JethroF250
its been since the tires were new. that was when we were bail hay with wes
