Cummins conversion
Old Mar 29, 2008 | 12:08 PM
mcallister's Avatar
mcallister
Cummins conversion
Has anyone done a Cummins conversion?? I have a 2002 Ford Excursion, 7.3 PSD. I have done a lot of mods........but in order to go further (more power), I have the Powered metal rods to worry about. I am already close to 400 RWHP (356), and 860 RW torque. I have a stock fuel system, stock injectors, stock turbo. So, to upgrade the turbo, injectors, fuel system, HPOP, I would be spending another 10-12 thousand. I know this would make my Ford "unpure", but just curious if anyone out there have done it.
mcallister
Old Mar 29, 2008 | 12:42 PM
1996pwrstrk's Avatar
1996pwrstrk
How are you getting 356 RWHP and 860 Torque on a stock fuel system , stock turbo, and stock injectors ??
Old Mar 29, 2008 | 12:49 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
My question as well.
Share the tricks.
As far as conversion to Cummins here's a start http://www.destroked.com/
Old Mar 29, 2008 | 01:32 PM
That_Guy's Avatar
That_Guy
I would love to hit those numbers as well with the stock set up, whats the secret???
Old Mar 29, 2008 | 01:44 PM
superduty4x4's Avatar
superduty4x4
Another site to check out is Ford Cummins
Old Mar 29, 2008 | 04:04 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Get on an accurate dyno. You DON'T have 356hp, ESPECIALLY with Banks stuff.
Old Mar 29, 2008 | 04:09 PM
1996pwrstrk
Hey Kris is this the same guy that was try'n to tell us he was getting 32 mpg with his X????
Old Mar 29, 2008 | 04:10 PM
HKusp's Avatar
HKusp
Kris is always pulling punches hehe.
Old Mar 29, 2008 | 04:25 PM
mcallister's Avatar
mcallister
Actually, after doing the math (manually) I am not getting 32mpg! My lie-o-meter is way off. I am averaging 15 in town, and 21 on the freeway. You can believe me or not, I did three runs on a dyno. I have the Banks Intercooler, Banks Big Hoss (set at 120 hp shot), mated with a six gun tuner, Banks Big Head Wastegate, 4" power elbow, compressor wheel, S & B air box, Monster exhaust, transcommand, billett torque converter, 356 RWHP, 860 RW torque
Old Mar 29, 2008 | 04:37 PM
PowerstrokeJunkie
Well, i don't believe you. Get on the same dyno i do, along with everyone el;se and you'll see that you have about 300hp if that, and around 600 lb-ft of torque. Are you sure you weren't reading HP and Torque from your Lie-o-meter?
Ifyou have the dyno graph, can i see it? What was the correction factor? 1.2?
Old Mar 29, 2008 | 04:38 PM
1996pwrstrk
Why did you lose hp 396 to 356 and torque 915 to 860 from this other post to this one ?https://www.ford-trucks.com/forums/7...re-ponies.html
Old Mar 29, 2008 | 04:39 PM
mcallister's Avatar
mcallister
Banks Intercooler, Banks Big Head Wastegate, compressor wheel, Big Hoss chip (set at 120 hp shot), Six Gun (set @ level 6, 62 horse), S & B Airbox, 4" power elbow, banks monster exhaust, transcommand, billett torque converter, each tanks treated with Diesel Kleen (cetane), essential lube, tranny fluid (roughly 1 quart to 100 gallons of fuel).
mcallister
Old Mar 29, 2008 | 04:42 PM
mcallister's Avatar
mcallister
I was wrong, I pulled my report and misinformed everybody.
mcallister
Old Mar 29, 2008 | 04:43 PM
PowerstrokeJunkie
Must have reset his Lie-o-Meter and punched it a few times.
Old Mar 29, 2008 | 04:48 PM
mcallister's Avatar
mcallister
Where did you dyno at?
mcallister
