transmission flush
Old Mar 29, 2008 | 08:12 AM
fortuitous24's Avatar
fortuitous24
transmission flush
I run a 2000 EX V 10 4X4 w/ 60k miles. I only drive it obout 5K a year now. Garaged from day 1. I was wondering when and if I should have my tranny flushed ? I tow my boat around 5 miles to the lake in the summer. It weighs around 4K #'s.
Old Mar 29, 2008 | 09:31 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes you should. It should be done every 30k miles.
Old Mar 29, 2008 | 10:02 AM
Downriver Thunder's Avatar
Downriver Thunder
I put 170,000 miles on mine before I did a fluid flush. Of course I put a new trans in at 200k.
Old Mar 29, 2008 | 05:40 PM
aortizexcursion's Avatar
aortizexcursion
The dealership should do the flush right? I can use Mercon V for the transmission right, because didn't Ford stop using Mercon and now Mercon V is compatible with it.
Old Mar 29, 2008 | 06:59 PM
fortuitous24
The thing that worries me is I have changed tranny fluid in the vehicles before, not a flush and once I changed the fluid and filter started having issues. Any others changed there fluid with a flush ?
Old Mar 29, 2008 | 11:05 PM
krcole's Avatar
krcole
Not an expert but my experience is if you check the fluid and it is still a nice red color then go ahead and change it if miles warrant a change and you are doing it a favor. If it looks otherwise just leave it alone because tranny problems will be coming sooner if you change it than otherwise but they are coming either way........
You can change it yourself with no problem. Tech folder has step by step but it's a little messy and you don't drive it too much according to you post. So if $150 every few years isn't a big deal to you then let the dealer do it and know it is done right and forget about it.
Old Mar 30, 2008 | 08:38 AM
Mark Kovalsky
I do mine with a flush each time.
https://www.ford-trucks.com/article/...nsmission.html
Old Mar 30, 2008 | 08:52 AM
aklim's Avatar
aklim
I had that happen to me before. Why? Because the tech took out the filter BUT LEFT THE RUBBER O-RING THERE. Then he inserted a new filter WITH AN O-RING. Later on, the filter fell out. Gee, I wonder why.
Other than that, I never had a problem changing filters and dumping old fluid. Those are old wives tales.
Hell, I even had it done at BTS. Dropped pan, overfilled trans, dump out 4 quarts out of the lines, overfilled again, dumped another 4 quarts then level checked. If it would have caused a problem, why would Brian do it there at his shop?
Old Mar 30, 2008 | 12:33 PM
aortizexcursion
So is Mercon V safe to use in the transmisson, or do I still have to use Mercon?
Old Mar 30, 2008 | 01:06 PM
ptolalibertad's Avatar
ptolalibertad
the fluid replacement issue has come up before..All i hear scares me, so just as always i drain and replaced the fluid, and replace the filter. I don't trust the fluid replacement. I've never had a transmission related problem on any of my vehicles.
Old Mar 30, 2008 | 03:49 PM
Mark Kovalsky
MERCON V has replaced MERCON for all applications that used to use MERCON. MERCON V has been changed to be compatible with the transmissions that used to use MERCON.
PStruwing
Feb 28, 2014 06:14 AM
Jjk27
Aug 2, 2013 01:44 PM
WMNY
Nov 12, 2010 10:02 AM
jwhopson
Mar 7, 2010 07:30 AM
durnan
Jun 26, 2003 07:44 PM
