Cab Mount question?
Old Mar 28, 2008 | 05:00 PM
Duke78's Avatar
Duke78
Cab Mount question?
Here is a picture of my driver cab mount.
http://good-times.webshots.com/photo...02354164FwwIwH
You can see there is surface rust around the seams. Do you think i should remove the cab mount, sand blast and then rust encapsulate? It looks like it's welded on so i'd have to do the dreaded cut and re-weld. Not sure how bad it is inside, i haven't cracked the inspection port yet. Just wondering what you all think.
Old Mar 28, 2008 | 05:56 PM
scrapyardking's Avatar
scrapyardking
Just brushing some rust bullet on it should do the trick.
Old Apr 13, 2008 | 10:36 AM
Hyperactive460's Avatar
Hyperactive460
judgeing by the reastlowe door and firewall it appears to be prety solid, mainly surface rust. tap on it with a hammer any sft sots won't sound the same as solid metal.
Gicknordon
25
Jun 3, 2014 07:08 PM
The Incredible Sloth
May 21, 2011 05:16 AM
Bruiser 1
Aug 4, 2009 03:38 PM
mdamico
Mar 2, 2006 08:41 PM
F250Rob
Aug 8, 2004 07:57 PM
