Sponsored by: Auxito
code 19 air bag
Old Mar 28, 2008 | 03:53 PM
Suicidal's Avatar
Suicidal
code 19 air bag
gotta air bag code of 19. What is it? What's the fix?
Old Mar 28, 2008 | 05:09 PM
ncranchero's Avatar
ncranchero
"B1231 19 RESTRAINT CONTROL MODULE Crash Data Memory Full".
Have you had an air bag deployment?
Old Mar 28, 2008 | 06:17 PM
Suicidal's Avatar
Suicidal
yes, trying to put everything back together. i have new airbags to replace them, just wondering what the code was and where to start.
Old Mar 28, 2008 | 06:42 PM
ncranchero's Avatar
ncranchero
Replace the RCM and it should clear your flash code. It's on the trans hump under the dash/ashtray area.
Did you replace the safety belt pre-tensioners?
Safety Belt Retractor Pretensioners
Vehicle not equipped with seat integrated restraints (SIR), the safety belt retractors are equipped with pretensioners. The belt retractor pretensioners rotate the safety belt retractors to remove excess slack from the safety belt webbing.
Safety Belt Buckle Pretensioners
Vehicle equipped with seat integrated restraints (SIR), the safety belt buckles are equipped with pretensioners. The safety belt buckle pretensioners remove excess slack from the safety belt webbing.
Old Mar 28, 2008 | 06:56 PM
ncranchero's Avatar
ncranchero
Your DTC & Lamp Flash Codes for future reference.
Restraints Control Module (RCM) Diagnostic Trouble Code (DTC) Priority Table DTC LFC Priority Description Action To Take
— — 1 RCM Disconnected, Inoperative, or Lost/Low Ignition Feed
B1231 19 3 RCM Crash Data Memory Full INSTALL a new RCM.
B1342 24 2 RCM is Faulted INSTALL a new RCM.
B1869 Tone c — Air Bag Indicator Inoperative
B1870 Tone c — Air Bag Indicator Shorted to Battery
B1871 25 14 Passenger Air Bag Deactivation (PAD) Switch/Module Fault G
B1877 46 24 Driver Pretensioner Circuit Resistance High
B1878 17 26 Driver Pretensioner Circuit Shorted to Battery or Ignition
B1879 17 26 Driver Pretensioner Circuit Shorted to Ground
B1881 47 25 Passenger Pretensioner Circuit Resistance High
B1882 18 27 Passenger Pretensioner Circuit Shorted to Battery or Ignition
B1883 18 27 Passenger Pretensioner Circuit Shorted to Ground
B1884 27 15 Passenger Air Bag Deactivation (PAD) Lamp Inoperative
B1885 46 24 Driver Pretensioner Circuit Resistance Low Go
B1886 47 25 Passenger Pretensioner Circuit Resistance Low
B1887 15 6 Driver Air Bag Circuit Shorted to Ground
B1888 16 7 Passenger Air Bag Circuit Shorted to Ground
B1890 27 15 Passenger Air Bag Deactivation (PAD) Warning Lamp Shorted To Ground
B1891 — — Air Bag Tone Warning Indicator Circuit Shorted to Battery or Ignition
B1892 — — Air Bag Tone Warning Indicator Circuit Shorted to Ground or Open
B1916 15 6 Driver Air Bag Circuit Shorted to Battery or Ignition G
B1921 21 4 RCM Bracket Ground Resistance High
B1925 16 7 Passenger Air Bag Circuit Shorted to Battery or Ignition G
B1933 33 9 Passenger Air Bag Circuit Resistance High
B1934 34 10 Driver Air Bag Circuit Resistance Low
B1935 35 11 Passenger Air Bag Circuit Resistance Low
B2477 54 — Module Configuration Failure INSTALL a new RCM.
C1414 29 5 Incorrect Vehicle ID
— — — No Communication with the Restraints Control Module (RCM)
a DTC: Diagnostic trouble code, retrieved using scan tool.
b LFC: Lamp fault code, flashed on air bag indicator.
c Tone will sound only if additional DTCs are present.
Old May 4, 2008 | 10:18 AM
grind1's Avatar
grind1
Thanks for list I have a 46 code and realized that there's a seat belt harness underneath the driver seat that appears to have a short.
Old May 4, 2008 | 10:43 AM
projectSHO89's Avatar
projectSHO89
No, it's not a short.
It's an open or excessive resistance circuit, just the opposite.
Check the connectors to the RCM and the pre-tensioner for corrosion or pushed/damaged pins.
Steve
Old Aug 18, 2008 | 09:34 PM
Suicidal's Avatar
Suicidal
Can you not just reset the RCM? Does the code 19 also pertain to the driver's pretensioner?
Old Aug 23, 2008 | 03:36 PM
Suicidal's Avatar
Suicidal
ok, i replaced the RCM. Now i have code 29. How do i fix this code?
Old Aug 23, 2008 | 03:42 PM
Fordtech1's Avatar
Fordtech1
Code 29 is for the passenger air bag deactivation switch. The bulb is probably bad.
Old Aug 24, 2008 | 01:15 PM
Suicidal's Avatar
Suicidal
Code 29 in the above post says incorrect vehicle id. And i don't have a pass. deac. switch on my truck.
Old Aug 24, 2008 | 04:31 PM
ncranchero's Avatar
ncranchero
You don't have one of these????
You would find LFC 27 is for a burned out bulb in the PAD switch assy.
But that aside, you still have a problem with/at the RCM. Is it the correct one? Examine the wiring, including the terminal pins in the connector.
From the 2002Ford Service Manual"
PINPOINT TEST X: LFC 29/DTC C1414 — INCORRECT VEHICLE IDENTIFICATION CODE
NOTE: Most faults are due to connector and/or wiring concerns. Carry out a thorough Inspection and Verification before proceeding with the Pinpoint Test.
Old Aug 26, 2008 | 01:34 AM
Fordtech1's Avatar
Fordtech1
Wow, I gotta get more sleep...What ncranchero said. Sorry bout the mis-lead.
Old Aug 27, 2008 | 10:03 PM
Suicidal's Avatar
Suicidal
No, i do NOT have one of those.
Old Aug 29, 2008 | 11:46 AM
LxMan1's Avatar
LxMan1
A Supercrew does not have that switch due to the full size rear seat.
