headers?
Old Mar 28, 2008 | 04:51 AM
894fseries's Avatar
894fseries
headers?
I have a 94 f150 302 and long tubes. Shortly after buying the truck i did a SAS (solid axle swap) . My issue is that now the headers are in the way for the front drive shaft. Does any body know of a brand that will hug the engine/trany close enough or will i just have to settle for shorties? Thanks for the help
Old Mar 28, 2008 | 07:21 AM
toddol1971's Avatar
toddol1971
If you cant use the long tubes, maybe I can take them off your hands.
Old Mar 29, 2008 | 05:56 AM
894fseries's Avatar
894fseries
that is very possible. another question would shorties off a fox body work?
Old Mar 29, 2008 | 06:59 AM
TexasGuy001's Avatar
TexasGuy001
The shorty headers for a fox Mustang would work if you redo the Y-pipe. They won't mate up to the factory Y-pipe. I have seen it done before, and I think that is all that was an issue.
Old Mar 29, 2008 | 10:04 AM
jchilcot's Avatar
jchilcot
what axle did you swap in?
Old Mar 29, 2008 | 09:35 PM
95F350XL's Avatar
95F350XL
The Fox shorties dont point down enough. But I have seen people make them work. I have long tubes on my F350, with the solid. I dont have any problems with them. Mine are flowtechs.
Old Mar 30, 2008 | 03:14 AM
894fseries's Avatar
894fseries
swapped a dana 44 out of a 78 bronco and the 8" lift springs. it still has alil squat in the front but didn't know untill after the install either that they are big block springs so it rides like a brick lol. oh well. im not sure what brand the headers r but they rubbed with the original front end in but not to bad. do ur flowtechs hang down below the trans cross member also. mine do and so the pipe was ran really weird over it.
Old Mar 30, 2008 | 10:28 AM
Conanski's Avatar
Conanski
Oh.. you got the wrong headers for the truck then.. what are they supposed to fit? Here are the Flowtechs on my F150...
A link to more exhaust pics... http://www.flickr.com/photos/motorstuff/collections/72157602815866941/
Old Apr 2, 2008 | 02:15 AM
894fseries's Avatar
894fseries
yeah im not sure what the headers are for then. they are kinda pointed down and out. did u just get the basic flowtechs and about how much did they cost?
Old Apr 2, 2008 | 08:30 AM
Conanski's Avatar
Conanski
This is what I have.. Flowtech 12504FLT - FlowTech Headers - summitracing.com
Old Apr 2, 2008 | 10:11 AM
4x2mudder's Avatar
4x2mudder
with the rare 302 boss engine swap in my truck i cant put headers on, my frame rail gets in the way. from my front exhaust port to the back of the frame rail its about 1' 10'' and i dont want to cut my frame
Old Apr 2, 2008 | 10:21 AM
Conanski's Avatar
Conanski
The Boss motor is a pushrod 302 based motor utilizing standard windsor style heads, I don't see why you would have any problems fitting standard 302 truck headers.
Old Apr 2, 2008 | 01:17 PM
4x2mudder's Avatar
4x2mudder
i dont know why i can't fit headers on that motor. ive never thought of shorties though. i thought longtubes was the only answer
Old Apr 2, 2008 | 02:03 PM
Conanski's Avatar
Conanski
Longtubes are the best solution.. and I don't see why they would be a problem either. Where did you get the idea you couldn't use them?
Old Apr 2, 2008 | 11:47 PM
88CougarCoupe's Avatar
88CougarCoupe
Im sorry But you Are WRONG about the "Boss heads" they are not Windsor heads! Windsor heads wish they Could be Compaired to the heads on a REAL BOSS. the heads on a BOSS are 351 CLEAVLAND 4v heads CLOSED chambered. Not trying to be a dick but correcting your error.
