headers?
Old Apr 2, 2008 | 11:50 PM
88CougarCoupe's Avatar
88CougarCoupe
Originally Posted by 4x2mudder
with the rare 302 boss engine swap in my truck i cant put headers on, my frame rail gets in the way. from my front exhaust port to the back of the frame rail its about 1' 10'' and i dont want to cut my frame
Do you have any pics of this Engine in your pickup. I was considering a Clevor setup for my truck but if I cant run Headers then the Mustang will Have to get the clevor and the Cobra (clone) engine into the Truck (with a different cam of course)
Old Apr 3, 2008 | 07:56 AM
Conanski's Avatar
Conanski
Originally Posted by 88CougarCoupe
Im sorry But you Are WRONG about the "Boss heads" they are not Windsor heads! Windsor heads wish they Could be Compaired to the heads on a REAL BOSS. the heads on a BOSS are 351 CLEAVLAND 4v heads CLOSED chambered. Not trying to be a dick but correcting your error.
Here's a link to the NEW Boss motor that was just re-introduced in 2007.. the one I think 4x2Mudder is using... hopefully he can confirm or deny.
Ford Racing Performance Parts [The Boss is Back]
Old Apr 4, 2008 | 01:18 AM
88CougarCoupe
im well aware of the NEW boss Block. but thats all it is is a Better than original BOSS block. When he said RARE I assumed he was running an Original boss Engine which would have the CLEAVLAND heads and not windsors. which would explain why hes having issues with headers. but if he is running aftermarket Windsor heads or original windsor heads then I dont see what the problem is with headers unless it's a motor mount issue. worn rubber alowing the engine to sit lower than it should be.. Again I wasnt trying to be a J/O about things just clarifying about the heads On the BOSS engines.
Old Apr 9, 2008 | 10:23 PM
894fseries's Avatar
894fseries
ok another quick question i ordered some flowtech long tube headers and i first pulled the header off on the drivers side because that is the one giving me trouble. well the header looks to be the same header. what should i look for that maybe the engineand tranny are leaning toward the back to give them this downward slant and be in the way if any one has any ideas it would help
Hollister150
Jan 6, 2009 11:28 PM
jason85351
Jul 11, 2008 07:36 PM
nobodyspecial
Offroad & 4x4
15
May 31, 2008 04:42 PM
rvthorne06
Nov 12, 2006 09:24 PM
OffRoadF-150
Offroad & 4x4
Dec 31, 2005 08:30 PM
