wierd problem with light
Old Mar 28, 2008 | 03:56 AM
slifer's Avatar
slifer
I have a light in a ceiling fan that turns on and off every few minutes. Itll turn on when i flip the switch, stay on a minute or two, then turn off. It stays off a few minutes then will turn back on. I've tried 2 new bulbs and they all do the same. Any idea what could cause this?
Old Mar 28, 2008 | 04:30 AM
oldgoat49's Avatar
oldgoat49
Broken or loose wire or maybe a bad switch. Either way I'd be finding out before taking a chance or a short.
Old Mar 28, 2008 | 05:23 AM
slifer's Avatar
slifer
Yeah I won't use it til I figure it out. I'm thinking about putting in a whole new ceiling fan. Thanks
Old Mar 28, 2008 | 06:29 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Thermal overload protection?
What wattage bulbs you got in there?
Old Mar 28, 2008 | 06:51 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Agreed!
My money is on a loose mechanical connection of the wires inside the ceiling fan, or, in the wall switch.
Turn off the circuit, then remove the wall switch and check the connections.
Replace the switch, also. Cheap fix. Maybe $3.00.
If that doesn't fix it, turn the circuit off again, then drop the ceiling fan and look at the wires, and the wire nuts.
My semi-educated guess is that the conductors are not tightly connected inside of the wire nuts.
Sometimes the installer (who/whomever it is) didn't strip the insulation back far enough, or didn't tighten the wire nuts enough.
Reassemble and test.
One question. . . . your house isn't wired with aluminum is it??????
If it is. . . disregard what I wrote and call in a licensed electrician to get that crap out of your house!!!!!!!!
Old Mar 28, 2008 | 06:54 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Does it have a remote control?
Old Mar 28, 2008 | 07:04 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Shoot!, I hadn't thought about that.
Old Mar 28, 2008 | 10:32 AM
slifer's Avatar
slifer
Thankfully I do not have aluminum wiring. I've tried 40 and 60 watt bulbs. I'll take a look at the switch and wiring today, thanks
Old Mar 28, 2008 | 10:37 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I could understand if it flickered.
Just doesn't make sense that it would cool down and come back on....
Old Mar 28, 2008 | 12:30 PM
pchristman's Avatar
pchristman
If it's on a dimmer switch, the solid state circuit could be overheating, then shutting off until it cools enough to re-switch. I'v heard of this problem before, when the dimmer is loaded beyond its cpacity.
Old Mar 28, 2008 | 01:09 PM
blue beast's Avatar
blue beast
The wire or connector somewhere is getting heated and it loses contact with the connector or wire it is in. Go over each connection in the circuit and make sure
they are tight. Be sure you kill the power at the box or the power will be sure to
kill you!! And keep your left hand in your pocket when working on household wiring
since the veins in your left arm go right to your heart!!
Old Mar 28, 2008 | 10:11 PM
slifer's Avatar
slifer
It is on a dimmer, I'm going to tear into it tonite. It's definately not a flicker, it'll go on and off for a couple minutes at a time. I've never seen anything do this either.
Old Mar 28, 2008 | 10:32 PM
50calmike's Avatar
50calmike
I've got the real answer; It's a ghost!!!!
Old Mar 29, 2008 | 01:16 AM
slifer's Avatar
slifer
lol yeah it did kinda freak me out when it first started doing it
Old Mar 29, 2008 | 09:01 AM
rebocardo's Avatar
rebocardo
Take the fan down from the ceiling and make sure the box is a fan box and then check the connections in the ceiling by undoing them, cutting, stripping, and putting a new nut on. I like to wrap the electric nuts and wires in tape too.
