is the frame brace on a 65 F100SWB the same width as a 79 F100? the reason for the question is my truck is an automatic and to remove the trans you must remove the brace at the radius arms to get it out. i have a 79 donor and it looks to have deeper drop than the 65 brace. will it swap out without a lot of modification?
thanks in advance for the help on this.
bill
aka "the ol' guy" reliving my past
The frame width should be the same, from back of the cab to the front bumper 65/ 79. Now the rear of the frame vary in width, on some of the
years / models. You may want to compare the 65 radius arm brackect
crossmember to see if there the same!
In 65 ford missed the uhh we rivited the damn thing in and now cant pull transmissions to service from the bottom.... Almost all 66s have bolts. most 65s dont...
If it is a factory 66 auto it will also have the small floor plate on the trans hump to adjust the intermediate band. most 65 dont...LOL...
