Have you pulled the valve body back out and looked it over to see if you put something in wrong? Not giving you a hard time, just trying to cover the basics before diving head 1st and saying your hosed!
i did pull valve body back out. the only thing ichanged was the green springs [it said for faster shifts to do this]so ijust put one back instead of 3.the lever outside the valve body if it wasent in the right spot could it posably cause this.it did also tell me to drill a hole in valve body to release fluid faster
Did you drill the hole? As for the lever not being in the right spot as per the destrutions, then that could be part of your problem. So I am guessing it was working with the 3 springs in it, and you pulled the body, removed 2 of the springs, and put it back in. Then this happened? You gotta give more info, I really don't want to do this this spoon feeding info as to how this happend to give you an answer.
yes sir drilled the hole.as far as instructions on the lever there was none.i dont know how much more info i could [spoonfeed you] the tranny worked but was the 3rd season in truck so it was tierd,this kit was supposed to fix that. so i crawled under the truck took it apart i followed the diagram step by step twice only doing the mods it told me to do.the springs are color coded and valves all back in origenal spots.this is the first time i have ever did anything
2 a c6 other than a filter change and bolt it up!so i guess maybe i dont know the info to give!i guess you know a c6 or you dont thanks alot for letting me amuse you!!
