92 f150 timing
Old Mar 26, 2008 | 07:55 PM
FourWheel's Avatar
FourWheel
92 f150 timing
I have a 92 f150 351 auto just wondering if i can actualy advance the timing
Old Mar 26, 2008 | 08:37 PM
FourWheel's Avatar
FourWheel
I guess what i'm asking is if i turn the distributor will the timng advance or am i making some other kind of adjustment soory i am not use to fuel injected motors
Old Mar 27, 2008 | 04:49 AM
EPNCSU2006's Avatar
EPNCSU2006
Yes, moving the distributor does alter the timing. If you set the timing by ear, just loosen the distributor clamp and proceed as you would with anything else. If you are going to set the timing using a timing light, there's a jumper plug called the SPOUT connector that you will have to pull to temporarily disable the computer advance. You can find the SPOUT connector on your 92 near the driver side hood hinge, possibly taped to the wiring harness.
Old Mar 27, 2008 | 06:10 PM
FourWheel's Avatar
FourWheel
what is a good starting point how many degrees advance for performance
Old Mar 27, 2008 | 07:50 PM
lgfuller's Avatar
lgfuller
dont try too much more than ten degrees advance. any more leads to a nasty pinging
