9 inch ford rearend
Old Mar 26, 2008 | 07:29 PM
royleexx's Avatar
royleexx
9 inch ford rearend
i bought a 1955 ford pu the rearend numbers are D2SW-C 2907 63 7M19
are there any place to go to find info on this rearend any info will help thanks roy
Old Mar 26, 2008 | 08:03 PM
country0001's Avatar
country0001
The D is the year which is a 70's. Since its a D2 that would be 72. There should be a tag on it to tell u the rest of the info.
Old Mar 26, 2008 | 08:05 PM
royleexx's Avatar
royleexx
i guess someone removed the tag and thanks for the info
Old Sep 30, 2019 | 12:52 AM
mustang7065's Avatar
mustang7065
Is from a 1978 f250 the gears are 320's and 58 inches across, Ford 9 inch rear. I have one also
Old Sep 30, 2019 | 12:53 AM
mustang7065
I have a 1962 F100 stepside it's for sale also
Old Sep 30, 2019 | 03:55 AM
My4Fordtrucks's Avatar
My4Fordtrucks
9” in a 1995? That can’t be good since there is no sensor in the rear differential. How good does the truck run? What transmission is in the truck?
Old Oct 1, 2019 | 01:40 PM
Bronco638's Avatar
Bronco638
1955 not 1995
Old Oct 1, 2019 | 02:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
i bought a 1955 ford pu the rearend numbers are D2SW-C 2907 63 7M19 are there any place to go to find info on this rearend any info will help thanks roy
This is an old thread (first 3 posts are from 3/26/2008). Then it was dug up yesterday by a that typed bogus info.
D2SW-C is the casting number off the 3rd member (pumpkin), doesn't mean diddly-do because casting numbers are foundry marks, cannot be cross referenced to Ford part numbers.
The casting date code 7M19: December (M) 19, 1977 (7). To identify it without the rear axle ID tag, the rear brake size would have to be known.
1980 Granada/Monarch/Versailles were the last cars to have a 9 inch.
Last year for the 9" in F100: 1983 / F150/Bronco: 1986 / E150: 1987. 8.8" integral rear axle introduced in 1983, 1983/86 F100/150/Bronco could have either.
No F250 of any year has a 9 inch.
53FOPAR
Jan 19, 2015 06:12 PM
rongcp
May 15, 2011 09:40 AM
67 429
Apr 25, 2011 05:17 AM
dj53
Mar 4, 2004 11:37 AM
odlib
Aug 4, 2002 04:58 AM
