dieseling f150
Old Mar 26, 2008 | 06:48 PM
blackinkforge's Avatar
blackinkforge
dieseling f150
hey everyone I have a 86 f150 with a 300ci L6 and it diesels when I cut it off anyone have this happen to them and how did you fix it ?also it idle at about 1500 and the manual says it should be good at about 800.Carb time? Please let me know.TIA Jason
Old Mar 26, 2008 | 10:35 PM
scrapyardking's Avatar
scrapyardking
Get some higher octane gas
Old Mar 26, 2008 | 11:16 PM
Franklin2's Avatar
Franklin2
The most common cause of diesel is when the idle speed is too high. Turn the idle speed down, and it shoud fix it.
Old Mar 27, 2008 | 07:54 PM
zpmps2's Avatar
zpmps2
diesel
<< what does diesel mean when your talking bout a gas motor? Running after you shut it off for a second? WHAT?
Taylor
Old Mar 27, 2008 | 08:18 PM
99whiteford's Avatar
99whiteford
If its an automatic,leave it in gear when you turn key of.It will kill engine dead.
Old Mar 27, 2008 | 08:38 PM
Franklin2's Avatar
Franklin2
Taylor
When you turn the key off, the engine will keep running really rough for a couple seconds up to maybe a minute.
Old Mar 27, 2008 | 09:09 PM
Harfend's Avatar
Harfend
I would assume you have a 1 BBL carb?
If so, make sure the 2 nuts holding down the carb body are tight. Double check all your vacuum lines for leakers then check the timing. Then reset the curb idle and the "anti diesel" screw on the lower part of the carb, passenger side.
My experince with "dieseling" has always had some timing/carb adjustment fix.
Good luck,
DEAN
jlcrump
Dec 9, 2016 10:52 AM
mikey89014
1997 - 2003 F150
17
Mar 5, 2011 07:22 AM
vettdvr
3.0L Powerstroke Diesel
29
Apr 19, 2008 04:08 PM
fordtruckman
2009 - 2014 F150
238
Sep 4, 2007 06:23 AM
hitecdan
2004 - 2008 F150
17
Dec 29, 2002 08:32 PM
