1995 F150 Help
Old Mar 26, 2008 | 04:48 PM
CB Junkie's Avatar
CB Junkie
Cool 1995 F150 Help
Today When I Went To Leave For School I Got In My 95 Ford F150 With The 4.9 Auto And Went To Take Off Down The Street And When The Truck Went To Shift In To Second It Lagged For A Second Then it Klunked And Jurked Really Hard When it Shifted And The Same For Third Anyone Know What Could Be The Problem? The Fluids Fine Also I Checked And The Speedometer Quit Working This Morning At The Sametime Any Help Would Be Very Helpful.
Also Does Anyone Know The Wiring Diagram To Put In An After Market Radio Because The Stock One Has A Lot Of Wires.
Old Mar 26, 2008 | 07:51 PM
brown 4x4's Avatar
brown 4x4
Sounds like you lost the vehicle speed sensor signal. The transmission won't shift right, and the speedometer, cruise, and ABS won't work. Check the wiring and connection at the sensor on top of the rear differential. My bet is a bad connection or something caught the wiring and tore it off or broke it.
FourWheel's Avatar
FourWheel
As far as i know the trans is controlled by speed so if speedomiter isn't working tranny isn't working
Old Mar 26, 2008 | 07:53 PM
waynaferd's Avatar
waynaferd
Go to Wal-mart and get a stereo adapter. You just hafta hard wire the adapter to the stereo harness then it plugs right into the factory harness.
Old Mar 27, 2008 | 12:00 AM
mmhoward's Avatar
mmhoward
When I had that problem, I changed many parts and it ended up being the throttle position sensor.
If you do change it, use a stubby phillips head screw driver and be carefull. Mine started to strip out when I was trying to remove it.
Old Mar 27, 2008 | 11:34 AM
CB Junkie's Avatar
CB Junkie
Fixed
I Fixed It All It Was Was I Pulled The Fuse For The Door Buzzer And I Put It Back In Last Night And Now Its Back To Normal
PalumboTruckBully
Jul 25, 2016 10:53 AM
Gunnerboy
Feb 7, 2016 02:21 AM
Sierra.
Dec 4, 2015 02:01 PM
johnperrigin
Sep 30, 2015 01:33 PM
gulfcoast
Oct 3, 2006 07:25 PM
