Surge?
Old Mar 26, 2008 | 02:33 PM
JethroF250's Avatar
JethroF250
Question Surge?
My dad just got a 2000 f-350 diesel. he said in the morn when its warming up goin down the road it will act like its got more boost. he said theres a noise towards te turbo, then more power then it slows back down. any ideas on what this might be?
Old Mar 26, 2008 | 02:38 PM
zx250's Avatar
zx250
Of the next Riffraff East
Sounds like he may be feeling the EBPV opening and closing. What is the temp where you are?
Old Mar 26, 2008 | 02:55 PM
aocabrown's Avatar
aocabrown
Description sounds a little ackward but I 2nd the EBPV comment....that is probably the sound he's hearing..but it definitely doesn't give more boost...it causes less.
Old Mar 26, 2008 | 06:29 PM
JethroF250's Avatar
JethroF250
its about 30 in the morn. and he said the truck acts like it has more power then lets back off. hes not giving it more throttle when it hapens either
Old Mar 26, 2008 | 06:46 PM
nhill2090's Avatar
nhill2090
Ah, this is not the EBPV. If he is crusing down the interstate does it fluctuate a couple MPHs when it does this without his input on the accelerator?
Im thinking throttle position sensor.
Old Mar 26, 2008 | 06:48 PM
JethroF250's Avatar
JethroF250
exactly he keeps steady throttle and it starts gainin power for like 30 sec and then stops
Old Mar 26, 2008 | 06:50 PM
zx250's Avatar
zx250
But why only in the morning when cold and only for 30 minutes?
Old Mar 26, 2008 | 06:57 PM
JethroF250's Avatar
JethroF250
thats what i'm confused about because if it were the ebpv then the truck would lose power not gain ???
Old Mar 26, 2008 | 07:00 PM
zx250's Avatar
zx250
It would gain as it opened the lose as it closed. This is only if he holds a steady amount of pressure on the pedal. Any accel. would cause the EBPV to open. It would also need to be cold where he is driving.
Old Mar 26, 2008 | 07:03 PM
JethroF250's Avatar
JethroF250
ok so its probly just the way the truck warms up then. cause i know with my 95 7.3 its a dog when the valve is shut but mine doesn't gain or act any different like what he was tellin me his does
Old Mar 26, 2008 | 07:34 PM
nhill2090's Avatar
nhill2090
it could be just the trucks way of warming up? i cant imagine 30 seconds being normal though, i was thinking more or less 2 or 3 seconds
Old Mar 26, 2008 | 07:40 PM
zx250's Avatar
zx250
Just wondering how old is the oil and what weight? Maybe too thick when warm?
Old Mar 26, 2008 | 07:53 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
For whatever reason, my throttle pedal position sensor (both of the bad ones) was much worse when cold. You can replace just the sensor and not the whole pedal assembly.
Old Mar 26, 2008 | 08:04 PM
nhill2090's Avatar
nhill2090
i seem to notice this trend in temperature also
Old Mar 26, 2008 | 08:09 PM
Izzy351's Avatar
Izzy351
It's the EBPV. To confirm, pull the electrical connector and take off one morning -- see if it acts "normal". It won't hurt anything, a lot of guys gut the EBPV completely.
