electric
Old Nov 20, 2002 | 12:37 PM
johnwhipple's Avatar
johnwhipple
electric
When I rev my 351 I have bright signals and headlights, at idle, there dim to nonexistent. I have a new battery and alternator. Any suggestions?
Old Nov 20, 2002 | 03:08 PM
HotWhlz85's Avatar
HotWhlz85
electric
No expert here but check the obvious things like belt tightness and wear. Something is causing the alternator to not charge at full strength.
Ron
Old Nov 20, 2002 | 03:26 PM
desperado_18_2000's Avatar
desperado_18_2000
electric
Check the belts etc, and make for sure your voltage regulator is good. If you've got a voltage meter you can test this yourself by starting the truck and letting it idle, connect the voltage meter and if its putting out anywhere from 13.7-14.1 volts it is charging and i would look elswhere. This same symptom happend to my buddies old truck, the one i have now, swapped the voltage regulator and everything is all good now.
HTH
Old Nov 20, 2002 | 08:46 PM
crash104936221's Avatar
crash104936221
electric
53 fatty
Florida Chapter
Mar 19, 2014 08:48 PM
darkman
Jul 30, 2002 06:57 PM
John7894
Jul 14, 2002 06:43 PM
amsnss
Apr 17, 2002 09:28 AM
tetraruby
Oct 15, 2001 05:41 PM
