95 won't start
Old Mar 26, 2008 | 10:36 AM
tbart16's Avatar
tbart16
95 won't start
95 7.3 PSD 150k auto truck runs great,but after you shut it off and try to restart it takes a couple shots of ether to start little help please
Old Mar 26, 2008 | 10:59 AM
250turbo's Avatar
250turbo
check glow plugs & g.p. relay ..be very careful with ether!
kurt
Old Mar 26, 2008 | 11:10 AM
IceboxFX's Avatar
IceboxFX
kurt
x2
either is baddd!
Old Mar 26, 2008 | 11:44 AM
tjbeggs's Avatar
tjbeggs
Is the truck hot or cold when it won't restart?
Old Mar 26, 2008 | 11:47 AM
Action4478's Avatar
Action4478
If you are saying you have a no start when warm..You may need to replace the IPR o rings ...The best bet would be to Check ICP ,either with a scanner ,or a guage setup ...Could be an injector o ring or a poppet issues also ...
The IPR O ring can be verified just by removing & looking at it...
Old Mar 26, 2008 | 12:03 PM
79f-250custom's Avatar
79f-250custom
remember not to turn on the glowplugs when you put that either crap in there. if you do it causes preignition and causes damage i dont even want to think about.
i would agree with action replace the IRP or you have a bad injector.
some one told me to check for bad o-rings on your injectors you start the truck, get it warm and then pull out or fuel filter. if the fuel is dirty there is a bad o ring? dunno if its true or not but some one else will chim in.
Mitch
Old Mar 26, 2008 | 02:30 PM
tbart16's Avatar
tbart16
all of a sudden truck starts every time I have been runnig it off and on all afternoon so I will keep everyone posted
thanks
