spout connector location? 1990 2.3 Ranger
Old 03-26-2008, 09:53 AM
crazypaw's Avatar
crazypaw
crazypaw is offline
Unhappy spout connector location? 1990 2.3 Ranger
Hi again all,
Wondering where spout connector is located & what it looks like
Trouble code: open or short - code 18 / test conditions: R & C
Old 03-26-2008, 11:37 AM
Noneshere's Avatar
Noneshere
Noneshere is offline
The spout connector (to the timing system) on a 1996, is on the main wiring harness , in the center of the truck that runs along the fire wall (near the hood seal). Theres a grey connector "plug". this is your spout connector . It's only about 1/2" X 1/2" x 3/8 thick and usually Grey in color.
This is where it is located on a 1996 2.3 liter
Old 03-26-2008, 12:49 PM
crazypaw's Avatar
crazypaw
crazypaw is offline
Red face spout plug
Hi Noneshere,
Thank you much for your answering my post and it's the same for my 90.
While I was waiting for a response I got the idea to look through my Hayes electrical schematics and it connects directally between the DIS Module and the EEC Module.
After tracing out the wires w/ a VOM and found no faults & the gray "plug" itself shows infinate continuity when I tested it.
I then realized that when I unhooked my EECM/PCM for inspection these wires must not have all reconnected themselves properly as noted by my previous post, the one that you answered.
And I also have the battery disconnected as I compose this post to reset the codes.
mike L
10-10-2016 05:14 PM
88F700
Large Truck
07-25-2013 06:51 PM
x_man586
22
09-04-2012 09:43 PM
92will
06-08-2011 05:24 PM
ziggy55
04-04-2010 05:26 PM
Quick Reply: spout connector location? 1990 2.3 Ranger
