5.0 Throttle Body Sizes HELP!!!
Old Mar 26, 2008 | 09:33 AM
Wolf0r's Avatar
Wolf0r
Post 5.0 Throttle Body Sizes HELP!!!
I have a 87 crown victoria 5.0 going in my F-100. I bought a throttle body gasket kit, it looks too big. It says fits 65/70mm. Obviously I need smaller, anyone know maybe what I have? Its the factory one. Where can I find more info on this? I know I should have bought a HO.
Rob
Old Mar 26, 2008 | 10:26 AM
Conanski's Avatar
Conanski
Crown Vic had a 55mm TB...
P.S. Don't sweat the HO, you're gonna upgrade the cam in that motor anyway aren't you.
subliminal message on... upgrade the cam.... upgrade the cam.. subliminal message off.
Old Mar 27, 2008 | 05:23 PM
LxMan1's Avatar
LxMan1
Yep, the standard 5.0 has a 55mmtb and the HO Mustang and Mark VII engines have a 60MM.
Old Apr 1, 2008 | 12:15 AM
Wolf0r's Avatar
Wolf0r
Well I bought the engine, trans, harness, pcm and instrument panel for $150. I drove the car before pulling everything, it ran great! I am not looking for power at the moment, I just want to get everything wired and converted. I plan on using full length headers, fitting a sensor bung just before the collector. I am thinking this will give a good reading even if I blow out a collector gasket. I have the factory cast iron manifolds but they look really restrictive. I have a complete 89 E350 van that I am taking the fuel tank and lines from. It has a 351w with a C6. But the windsor has a thrown a rod.
Old Apr 1, 2008 | 12:18 AM
Wolf0r's Avatar
Wolf0r
Also I have 3:00 gears. I plan to use the AOD also. Should I get the ratio the vicky used? I am using 235 70r 15 tires.
Old Apr 2, 2008 | 10:34 PM
LxMan1's Avatar
LxMan1
The Vicky probably had a 3.08 so I would try the 3.00's for now.
Then go to 3.73's later.
Old May 13, 2008 | 04:24 PM
Wolf0r's Avatar
Wolf0r
Thanks, I'm all set to install everything soon as I get the cab rust repaired. I have cab mounts and floors coming from LMC. Hopefully I can find a good doghouse for it next.
new7.3owner
Jul 27, 2014 04:39 PM
gov2mod
1978 - 1996 Big Bronco
Aug 15, 2004 06:07 PM
93superflare
Apr 18, 2004 09:29 AM
john stidman
Apr 1, 2004 11:31 PM
Rodommoc
Nov 15, 2003 02:32 PM
