Sponsored by: Real Truck
Oil Leak
Old Mar 26, 2008 | 08:09 AM
dagren99's Avatar
dagren99
Oil Leak
My 00 7.3L has developed an oil leak - the origin of which I can't find so far. The leak is on the driver's side -oil is coating the side of the block (oil streak is about 6-7 inches wide) and running down onto the oil pan just behind the spin on oil filter. Its a slow leak as nothing is hitting the ground and the area is just damp w/ oil not running. No oil in the Valley that I can see/find.
I originally suspected the turbo pedestal o-rings but since nothing is in the valley I'm starting to wonder about that conclusion. Leak is only on the drivers side. I checked to see if it was coming from the CCV or valve cover on that side and both are dry.
I'm going to look at this more over the weekend but I do not want to dig into the turbo pedestal until I'm sure that's where its coming from.
Is there something on the back of the block/cyl head this could be coming from?
DG
Old Mar 26, 2008 | 08:12 AM
dagren99's Avatar
dagren99
Move ??
OOPS! - I should have posted this over in the 7.3L forum.. Move ??
DG
Jesser02EX
Jun 22, 2013 11:03 AM
TurfSpecOK
Mar 21, 2012 05:11 PM
LSO1123
Nov 18, 2011 04:33 AM
disneyd
Apr 14, 2011 11:50 AM
powderspecial600_98
Jul 7, 2009 08:53 PM
