1978 - 1996 Big Bronco
Driver side panel removal
Old Mar 25, 2008 | 10:39 PM
heymrdj's Avatar
heymrdj
Can anyone tell me a writeup to remove the drivers side panel of a 95 EB Bronco? I need to change out the driver's side window gear.
Old Mar 29, 2008 | 08:52 PM
blue beast's Avatar
blue beast
Do you mean the plastic door panel or to actually get to the motor?
The panel is held on by those cheap plastic clips that always break
they make a special tool to remove them but a long flathead works
just as well. There are three dimples that you have to drill out to get
the motor out since they block the bolts that hold the motor to the
regulator. You will need a phillips head driver, along flat head screwdriver
a drill, A half inch drill bit and a set of sockets to get the motor out.
Usually you only need the three little pins that go inside the gear and
you can save alot of money by making your own pegs out of either a
wood dowel with rubber around them or if you can find nylon round stock
that would work the best. Don't go and buy the whole motor until you
get the old one out since they sell the gear and pegs seperately for like
$10.00 compared to whatever a whole motor goes for.
Old Mar 30, 2008 | 07:04 AM
b4hntn's Avatar
b4hntn
To remove the entire panel just lift it up a little after removing all the screws and prying the clips out of the holes in the metal door.
