Sponsored by: Real Truck
Help with trans temp guage purchas
Old Mar 25, 2008 | 10:39 PM
firefighter1204's Avatar
firefighter1204
I need to get a trans temp guage. I see that it is best to place it in the side of the trans. What size NPT fitting is that? I think I seen where it was 1/4 inch? Is electric or mech. guage better?
Old Mar 26, 2008 | 12:15 AM
ReAX's Avatar
ReAX
That hole is NPT, so it looks much larger than it's spec'd. I think it's either 1/4 or 3/8" npt. The sender should be 1/4" and a 3/8" adapter bushing should be included with the gauge/sender.
For gauges, do you want trans fluid in your cab? That's the real difference. I'd go electric for the extra $20. I don't mind mechanical for vacuum and boost, but I'd rather keep all fluids out of the cab. Also, I'd go for a full sweep, short sweep electrics look cheap to me, even the expensive ones.
Also, buy a quality gauge. They aren't that much more expensive but much more reliable. I went autometer because I had sold them for 10 years before I had access to VDO, Stewart Warner and ISSPro. Now, I wouldn't mind using either ISSPro or Stewart Warner or VDO. ISSPro does look a little cleaner though.
Old Mar 26, 2008 | 01:57 PM
missouguy's Avatar
missouguy
I have the triple ISSPRO setup on the A piller. With the green bulb covers it looks just like the factory. Also with the amp box it makes the large sweep which I like.
Frank
Old Mar 27, 2008 | 02:38 AM
thedaddycat's Avatar
thedaddycat
I have the DiPricol Optix gages and they match my dash to a tee. I have added a selector switch to the trans temp gage so I can use one gage to monitor up to six parameters. I have temp probes in both diffs, the tranny and engine block (coolant) and will add one for oil temp. My probes are all 1/8" NPT.
https://www.ford-trucks.com/forums/6...ut-gauges.html
Old Mar 27, 2008 | 06:56 AM
bbender85's Avatar
bbender85
i use the GloShift trans temp, works good and the selectable green backlight matches the dash well, and the text is close. came with the sending unit that went right into the test port on the trans.
Old Mar 27, 2008 | 07:58 AM
5.4L to Freedom's Avatar
5.4L to Freedom
Sorry to sound like a newb but guages and stuff are out of my realm of knowledge... what is this 'full sweep' and is there anywhere I can mount guages OTHER than the a pillar? I like my grab handle and do not think I could get my fat... in without it.
I need to mount a voltage guage and trans temp, is there a third guage I could use as well?
I know on my old '89 350 with an ATS turbo I had 2 VDO guages that where in 4.5" long black 'tubes' on a swivel mount. Do they still make this style? If so what are they called
Old Mar 27, 2008 | 08:09 AM
missouguy's Avatar
missouguy
I have seen some gauges mounted under the rearview mirror, have seen as many as three. I just liked the A-piller. Full sweep are just numbers that go around the gauge about 270 degrees. I like them as the movement is easier to see.
Just personal preference I guess.
Frank
Old Mar 27, 2008 | 10:58 AM
thedaddycat
I got my setup from ITP Diesel, a site sponsor. This page should give you an idea of what's out there:
http://www.itpdiesel.com/store.php?crn=139
Old Mar 27, 2008 | 11:50 AM
MeyerzF350's Avatar
MeyerzF350
I would call Diesel Manor. They will mail you everything you need with instructions.
Old Mar 27, 2008 | 12:34 PM
5.4L to Freedom
The question I've never seen an answer too is what is wrong with the in dash guage? As far as i understand shouldn't it work just like an aftermarket one, and if its not responsive enough can't you just put a better sending unit or whatever goes on the trans and wire that into the stocker?
Old Mar 27, 2008 | 12:48 PM
MeyerzF350's Avatar
MeyerzF350
No comparison. The aftermarket gauge tells you what the actual temp is. The in dash gauge has two settings. Cold or it sits directly in the middle after it warms up.
Old Mar 27, 2008 | 02:06 PM
ReAX's Avatar
ReAX
Right, it's more a question of quality of sending units. The stock senders may have up to four outputs, low, just right, alittle high and too high. Aftermarket/competition gauges sending units will send a voltage that directly correlates with the pressure it's sending in 1/10 of a volt or lower increments.
Sweep is how much movement the needle can travel from low to high. The move it moves will give you either more range or finer accuracy. Another thing to consider in sweep is the direction of travel. I love driving by a vacuum gauge, it helps me keep my foot out of the pedal, but the needle on a vacuum gauge moves to the left as vacuum decreases, unlike my oil pressure and A/F ratio which move to the right as I get on the gas. To get around this, I picked up a Vac/Boost gauge which moves the needle to the right as vacuum decreases. I did this so when I put my foot on it, all of my gauges move in the same direction and I can read them in nearly the same orientation rather than having to scan for the needle as I am driving.
Old Mar 27, 2008 | 02:07 PM
ReAX's Avatar
ReAX
Have you found a free port in the pressure side of the oil passages or were you planning to Tee if off of the stock sender?
Old Mar 27, 2008 | 02:08 PM
bbender85's Avatar
bbender85
my truck didnt come with a trans gauge, so i did that and oil temp (since i have oil pressure on the cluster)
Old Mar 27, 2008 | 02:09 PM
bbender85's Avatar
bbender85
also, here's a clip of mine:
