302 EFI not running
Old Mar 25, 2008 | 08:51 PM
kenworthfan's Avatar
kenworthfan
302 EFI not running
I had my 1986 F150 4x4 with a 302 EFI out last week and drove it about 50 miles and everything ran great. Then a few days later I went out to start it and it fired a few times and then died off. I tried again and it did the same thing. This happened a few times and then it finally started to idle but was missing bad. I went back to it later and it did the same thing, so I talked to the mechanic at my dads work and he said to replace the fuel filters. I changed both fuel filters and it was a little bit better but not much. Then he said to replace the secondary fuel pump, that didnt help any either. I recently got a new Jasper Engines longblock put into it and when they put that in they replaced the knock sensor, the IAC, and gave it a whole tune up. They didnt replace the TPS though. Could that be the problem or do you guys think it is something else.
Sorry for the long post, thanks in advance for the help,
Blake
Old Mar 26, 2008 | 12:05 AM
Franklin2's Avatar
Franklin2
Don't guess. Pull the codes from the computer. If it sees a sensor bad, it will tell you so. Here's a site that tells you how to pull the codes with a testlight or voltmeter. www.fordfuelinjection.com
