left-front rumble after right turn
Old Mar 25, 2008 | 08:17 PM
ejessee's Avatar
ejessee
I have a high frequency rumble after making a right turn at a stop sign. It only happens 1 or 2 times right after I leave home in the morning and seems to only happen if I come to a stop or near-stop and then make a right turn. A rumble or "roar" is the best way I can describe it and it seems to come from the left front fender well area. Any ideas? cv-joint?
Old Mar 25, 2008 | 09:36 PM
madsonp's Avatar
madsonp
Check your sway bar bushings, your shock bushings, and A-arm bushings. These are the rubber isolators between the different parts.
Old Mar 25, 2008 | 10:23 PM
projectSHO89's Avatar
projectSHO89
Wheel bearing or, if a 4X4, check the CV joints on the LF half-shaft.
Steve
Old Mar 26, 2008 | 05:25 AM
davisenvy's Avatar
davisenvy
Wheel bearing.
