Sponsored by: Kumho
hard brake pedal
Old Mar 25, 2008 | 06:32 PM
rhgibson's Avatar
rhgibson
hard brake pedal
my 1996 ford f-350 has a brake pedal that varies. Sometimes its hard and you have to push hard but stops the truck fine. Other times it feels normal. The brakes have alot of pad left and the master is full. It was making a cliking sound under the dash like a switch but the sound is now gone. I have checked the abs unit and it tested ok.
Old Mar 27, 2008 | 03:45 PM
4x4LONGBOX's Avatar
4x4LONGBOX
Check for a vaccuum leak in the line that goes from the intake to the brake booster. Also try applying vacuum to the booster manually with a mityvac and see if it holds vaccuum.
Old Mar 27, 2008 | 08:36 PM
4x4LONGBOX's Avatar
4x4LONGBOX
Oh yeah and the obvious... try replacing the Vaccuum check valve, it may have some dirt or debris or something causing it to hang up a little sometimes. You should only be able to blow through it one way.
jfowler1
Oct 3, 2015 10:28 AM
stephenok711
Jun 2, 2012 05:59 PM
cr506
18
Apr 8, 2010 08:16 PM
Jbrown8988
13
Nov 15, 2009 10:54 AM
XPLR/R
Jan 24, 2007 07:11 PM
