Annoying engine problem
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds
.Check out my Gallery for a look-see.
Justin - One Happy FTE Member
>expect to fix anything. You also cannot troubleshoot one
>over the internet. Quit being such a tightwad and go buy a
>$40 code scanner and do an Engine Off and Engine Running
>test. I've never needed anything more than one of these
>scanners to pinpoint a problem. Incidently, you blew off
>the guy that suggested the throttle position sensor. These
>are notoriously flaky on these engines, but hey, I'm sure
>that's not what it is since you said so. Also, feel free to
>"laugh at such stickers" and hose out your throttle body
>with whatever you choose. That sticker isn't there to keep
>you from ruining the delicate coating inside the throttle
>body and IAC valve or anything else important like that.
>It's really just just to protect the service tech's job in
>much the same way that the DO NOT SMOKE signs at the gas
>pumps are there to protect the ambulance driver's job.
I didn't think it was the TBS because I didn't have the same symptoms as him. I know I am not suppose to "just throw parts at an EFI system", thats why I'm trying to troubleshoot before I buy a part. My idle air control valve is the "not cleanable" type, therefore I figured it would have to be replaced if there was something wrong with it. I don't see why you can't troubleshoot one over the internet, I'm doing ok so far. Sure it's more trouble but it can be done. A code scanner is $40 dollars out of my pocket that I'm trying to prevent the loss of. I don't like to throw my money out when I don't have to.
