Original Style Hubcaps
Old Mar 25, 2008 | 12:30 PM
tacson's Avatar
tacson
I have the Gennie style wheels on my truck.
I am using the chrome version of the original hubcaps. It is often a bear to get them off without scratching some paint off the wheels themselves. Has anyone created a tool or have a tip for the best way to remove them? I dont take them off often but I do like to check my brakes and such. Thanks for any and all help
Old Mar 25, 2008 | 12:39 PM
Truxx1956's Avatar
Truxx1956
Talking
Hey Donald, I dont know how tight yours' fit, but with mine I just pull them off by hand. They are pretty tight, but I do have a bear grip. If you need something else, you can use a nylon tool like they install windshields with??
How's your wife doing?
Old Mar 25, 2008 | 12:40 PM
ontariowestcoast's Avatar
ontariowestcoast
This is what I have used in the past. Is a 1-2in wide by 10in piece of heavy plastic sanded down to a point. Lightly round all edges. Something like a wedge. It doesn't scratch the paint.
Old Mar 25, 2008 | 01:11 PM
GreatNorthWoods's Avatar
GreatNorthWoods
I took a large old screwdriver, heated about the last inch or so and bent it down about 130 degrees. Then I wrapped the tip with electrical tape. It does a good job.
Old Mar 25, 2008 | 01:57 PM
tacson's Avatar
tacson
Terry,
The wife is fine. Keeping her fingers out of closing doors.
Ontario your tool sounds best but I have better success coming up with the tool GNWoods mentioned. Thanks for the help fellas
Old Mar 28, 2008 | 01:06 PM
peecubed's Avatar
peecubed
I brought this up awhile ago around here. My truck had an old tire iron stuffed behind the seat when I bought it. Turns out one end is perfect to pop the caps off. I don't know if its original or what, but it works great. One end is flattened and kind of spoon shape and slips behind the cap edge. It fulcrums off the edge of the rim and a rag or something can be put behind it when poping them off. If it chips any paint its always behind the hubcap. Here's a picture of it.
<imgsrc="http: img.photobucket.com="" albums="" v720="" ptelford="" dscf2970.jpg=""></imgsrc="http:>
Old Mar 28, 2008 | 03:28 PM
53ford's Avatar
53ford
I have the same type of tool that came with my 53. I believe it probably came with the truck. I can verify its existence back to 1963, when my dad got the truck.
Old Mar 28, 2008 | 03:29 PM
53ford's Avatar
53ford
I have the same type of tool that came with my 53. I believe it probably came with the truck. I can verify its existence back to 1963, when my dad got the truck. Works well too!
Old Mar 28, 2008 | 04:14 PM
Okiedokie's Avatar
Okiedokie
And they sure look good on there. I have the same on my 46 and also use the tips of my fingers to pull them off, yes it takes some effort and use my knee to keep the cap from falling. I also have used a bearing pulling tool that has a tip on one end and the other end has a handle to hold with an arm to hit with a hammer. It does remove the cap without damage to the wheel or cap, but is very hard to use and control the cap at the same time, if that makes any sense. Try using the tips of your fingers to "pry" with. Joe
Old Mar 28, 2008 | 09:44 PM
Bob at warsaw's Avatar
Bob at warsaw
Hi Donald
Nice orginial hubcaps, dont pry to hard to harm them
Take care
Old Mar 28, 2008 | 10:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Nylon mixing spoons (for cooking) have about a 1/2"-dia. round handle. Cut off the spoon end just about 1/2" below where it transitions to round handle. Grind like Ontario said. The shape is just about right.
Old Mar 28, 2008 | 10:39 PM
Bob at warsaw
I guess thats why they made a tire spoon
Old Mar 29, 2008 | 11:50 PM
tacson's Avatar
tacson
Thanks fellas. Will check the kitchen drawers in the morning for a spoon. Who's name can I use when the wife says "Have you lost your mind?"
StarFox
13
May 23, 2022 06:51 PM
ajbremer
Feb 13, 2015 04:08 PM
51f1truck
28
May 15, 2010 09:30 PM
cordino
Dec 4, 2009 10:40 AM
