I am working on a 1979 F250 4x4 front differential.
I removed the tag and its reads as follows: 3.54 EOTA JE 610063-1
From what I could find on the forum it’s a Dana 44 with a ratio of 3.54, am I correct? If so is this all the info I need when ordering a Ring & Pinion?
And also any idea where to purchase rebuild set with out breaking the bank?
<o>> </o>>
Thanks Dale
Hold on here... Are you sure that is not a 1980 axle or truck?
Welcome to FTE
Ford ID # E0TA-JE / Dana ID # 610063-1 / Dana 44HD / 3.54-1 / Free Running Hubs / Non Limited Slip / 3800 lb. Front Axle Capacity
1980/89 Ford Light Truck Parts Catalog / Front Axle Application Chart / Section 30 / Parts List #30.3C
If you can't find gear parts from a sponsor, then there is an ebay store called discountgearing that sells gear sets and parts for axles. They have over 2000 feedbacks and 100% positive rating. NO, I am not employed by them. A friend purchased a gear set for a jeep cherokee and was happy with the quality.
