1978 - 1996 Big Bronco
Another code reader question
Old Mar 25, 2008 | 08:04 AM
helirich's Avatar
helirich
I want to buy a code reader. I read the posts below and I have a question. When you plug it in, it says for instance, the throttle possision sensor is bad. It says this in words, right! I dont want to pay a hundred bucks for a fancy box that has me counting buzzers or lights.
Old Mar 25, 2008 | 08:16 AM
lenny1carl's Avatar
lenny1carl
for 100bucks i think your getting lights and or beeps..especially OBD 1
Old Mar 25, 2008 | 12:02 PM
b4hntn's Avatar
b4hntn
The black and yellow DIGITAL code reader (no blinking lights but numbers) has a nice book that lists the codes meaning, explains the three codes, KOEO, CM, KOER and even has a way to check the cylinder balance to see if there is a weak cylinder. It can clear codes also. Good book. If you don't move very fast from front tire to seat get the optional extension cable for the wheel turning, gas pedal mashing, OD button tests for KOER.
Old Mar 25, 2008 | 03:34 PM
helirich's Avatar
helirich
Numbers are ok, as long as I'm not counting. I assume you mean the reader says "64" and the book says 64 means throttle possision sensor.
Old Mar 25, 2008 | 06:56 PM
b4hntn's Avatar
b4hntn
Exactly.....
