timeing chain
Old Dec 2, 2002 | 10:34 PM
EricB's Avatar
EricB
timeing chain
[updated:LAST EDITED ON 02-Dec-02 AT 11:35 PM (EST)] Today I was out driveing and my engine just quit .
its a 79 302 , I ran the #1 piston to tdc and rocked the Harmonic
back and fourth,had about 1 1/4 inch of slop, you guys suppose my timeing chain is dead ?? Had good compression on the cylynder's,plenty
of gas etc,etc??
Old Dec 3, 2002 | 01:03 AM
BB's Avatar
BB
timeing chain
What's 1 1/4 inches of slop? Use the marks, when the slop gets to around 15 degrees going back and forth, the chains about ready to jump. If your chain jumped, you would have no compression.
An engine needs three things to run and you say you already have two, compression and fuel. I'd say your module died. Take it to any good parts house and they will test it free. Worth a try. Have you pulled a plug wire and tried to draw an arc?
Barry
Old Dec 3, 2002 | 08:26 AM
EricB's Avatar
EricB
timeing chain
ok,when you say that there should be no compression,,do you mean none at all or just very weak ?
I dont have a guage,used the old finger trick.
Thanx
Old Dec 3, 2002 | 09:35 AM
BB's Avatar
BB
timeing chain
Very weak, go ahead and buy a gauge, it's a good investment.
Barry
Old Dec 3, 2002 | 12:41 PM
EricB's Avatar
EricB
timeing chain
Yep,your right,just went and bought a guage,no compression hardly at all.
Thank You very much.
Old Dec 3, 2002 | 12:45 PM
Rosati's Avatar
Rosati
timeing chain
If you need to figure out how to realign everything, try the following link. It's for a 351 but all is the same.
http://www.clubfte.com/users/krosati/351W_Engine_Swap.html#timing
Old Dec 3, 2002 | 02:55 PM
BB's Avatar
BB
timeing chain
No problem, sorry to hear of your dilemma.
The chain is not that hard to replace, it's getting to it that takes all the time.
I replaced the chain and sprockets on my '79, it was so loose I could remove the chain with the sprockets still on! Also, the bolt in the center of the cam wanted to seize coming out. Had to work it back and forth slowly inching it's way out. Don't want to break that sucker. Good luck!
Barry
Old Dec 3, 2002 | 05:49 PM
EricB's Avatar
EricB
timeing chain
[updated:LAST EDITED ON 03-Dec-02 AT 06:50 PM (EST)] Tore the engine down,the chain came off by hand the top top gear was ate up pretty bad
Waiting on parts.
Thanks again guys.
Old Dec 3, 2002 | 08:35 PM
Polkat's Avatar
Polkat
timeing chain
