Overdrive trouble.
Old Mar 24, 2008 | 07:21 PM
r_b_burg's Avatar
r_b_burg
Overdrive trouble.
I have a 2000 Expy and when I went to tow this week I pushed the end of the shifter to turn the overdrive off and it won't turn off.
Does anyone know what things I can look at to try to fix it??
Thanks
Old Mar 24, 2008 | 09:21 PM
ExpySport's Avatar
ExpySport
Is your O/D light on the end of the shifter flashing, by chance? I had the same issue with my 2002 Expy at 12,000 miles. There was a faulty sensor in the transmission which went bad. The dealership replaced the sensor and no problems since then. When you push the O/D button, does the light illuminate on the shifter to indicate the O/D is "off"? Might be the fuse for the O/D circuit.
Old Mar 25, 2008 | 07:48 AM
r_b_burg's Avatar
r_b_burg
It doesn't come on at all when you press it. Where is that fuse located?
Old Mar 25, 2008 | 08:32 AM
SBastow's Avatar
SBastow
This happened on my 99. Turns out the wire was cracked. Replaced the entire shift handle which included new wire. Check the fuse first though.
Old Mar 25, 2008 | 09:12 PM
r_b_burg's Avatar
r_b_burg
Fuse fixed it. Thanks.
drrmwall
Mar 3, 2010 10:23 AM
tfink3
2004 - 2008 F150
Jan 6, 2010 03:34 PM
Prozon
Offroad & 4x4
Aug 12, 2008 10:35 PM
Leader
Mar 10, 2007 08:57 AM
theafus
1978 - 1996 Big Bronco
Dec 10, 2005 01:51 AM
