1978 - 1996 Big Bronco
Overdrive Light won't come on
Old 07-26-2005, 01:16 PM
theafus's Avatar
theafus
theafus is offline
The overdrive light that says"off" on the shifter does not come on when I turn the overdrive off is there a bulb I need to change out or is this a sealed unit everything works just fine but the "off" light does not come on.
Old 07-29-2005, 08:40 PM
theafus's Avatar
theafus
theafus is offline
Nobody? Does anyone know where I could find out if there is a bulb or if it sealed
Old 07-29-2005, 08:53 PM
G BOBKA's Avatar
G BOBKA
G BOBKA is offline
I think the light is under the dashboard and it shines through a plastic tube trace the cables on the column and good luck
Old 07-30-2005, 02:25 PM
theafus's Avatar
theafus
theafus is offline
Thanks I will try that
Old 12-08-2005, 09:24 PM
TwowhL's Avatar
TwowhL
TwowhL is offline
What did you find out with your OD light? Where is the bulb? Mine is doing the same thing.
Old 12-09-2005, 02:38 AM
muckypaws's Avatar
muckypaws
muckypaws is offline
On my 92 the light is an LED integral in the OD pushbutton at the end of the column lever. Pull off the round plastic bezel at the end and the switch can be slid out - its a three pin cylindrical thing. They are cheap to replace if the LED has indeed gone but since its an LED which generally will have a 100,000h life time it would be unusual for it to have failed. If you're feeling brave and can read electrical circuits you can work out which pin is the switch contacts and which is the LED (there is a common ground between them - hence only 3 pins) and then test the LED and switch with a multimeter and a small battery (c. 1.5V).
I would also check you have +12V on one of the pin sockets at the end of the switch and that one is ground. You can try and fool the system by shorting out the correct two pins to simulate a button push and see if the 3rd pin becomes live to energise the LED. I TAKE NO RESPONSIBILITY FOR DAMAGE IF YOU GET THIS WRONG.
The push button is very cheap to replace (cost me £19 when I ordered it in the UK so its probably only about $10 in the US).
Also, if it was like mine (and after I'd bought the button) you might fine the wiring is severed in the column. Remove the top cover of the column and you can trace where the wire comes out the centre of the column lever. There was an inline plug on mine so I could take it all off and resolder the wires together and hey presto it worked (and now I have a spare switch unit which I'd happily give to you but it would be cheaper to buy one in the US than send it back to the US from the UK).
Obviously this all relates to my '92 and as you don't specifiy the year of your is might be slightly different.
I can send circuit diagrams/ more pictures if necessary if my PM me an email address.
Good Luck
Simon
Old 12-09-2005, 02:50 PM
theafus's Avatar
theafus
theafus is offline
I bought a button from Jeffs Bronco graveyard and it works great I believe it was only ten bucks thanks all.
Old 12-10-2005, 01:51 AM
jcp123's Avatar
jcp123
jcp123 is offline
I have this trouble - the stick has a little play in D, so I just push it up to the top of its range of motion and presto, everything works great.
patsalters
09-11-2013 09:43 AM
Joeymt3
04-25-2010 03:54 PM
savage2211
12-14-2009 02:23 PM
Leader
1997-2006 Expedition & Navigator
03-10-2007 08:57 AM
maevans
03-06-2007 03:49 AM
Quick Reply: Overdrive Light won't come on
