2001 F350 S/d
Old Mar 24, 2008 | 01:57 PM
69-highboy's Avatar
69-highboy
2001 F350 S/d
Gents, I found a 2001 S/D with 72K miles for $21k. Between KBB & NADA, the asking price seems to be reasonable so I am giving it serious consideration. It is on its second owner and appears to be straight except for the usual parking lot dings. No extra holes, no gooseneck hitch and no leaks were visible, but I've yet to drive it, so I'm witholding judgement until I can get the local stealership to run an OASIS report. Amazing what one can learn by lurking, no? Other than the brakes were prone to warpage that year and the E4OD diode issue, what else should one be looking at for the '01 model year? IIRC the seller told me it also came with two sets of factory wheels (summer/winter) tires and a fiberglass topper. It has running boards, but I don't remember if the box had a liner -I think it was just a rubber mat.
Looking at the tailgate revealed that it was originally a Canadian truck (a dealership sticker). Would this make any difference in original equipment, or asking price?
Thanx in advance, 69-highboy
Old Mar 24, 2008 | 03:14 PM
uliman's Avatar
uliman
Pretty good price but you can probably negotiate it down to $20k. I bought my 01 but it was a dually 4x4 CC LB for $18,500 about 6 months ago with 96k miles on it. Yours is obviously a lower mileage truck so all in all a pretty decent price. Remember these trucks, especially the diesel, really retain their value. When I was looking back last September I actually had a hard time finding what I wanted. I had to fly to Texas from Vegas to get my truck. Best of luck with the new purchase.
Old Mar 24, 2008 | 03:19 PM
HKusp's Avatar
HKusp
I believe the Canadian trucks came equipped from the factory with daytime running lights but other than that it should be pretty much standard.
Old Mar 29, 2008 | 09:48 AM
69-highboy's Avatar
69-highboy
Gents,
I drove that truck yesterday and it's a dream. Down by my left foot I found a DP tuner with no adjustments that I could find, and under the hood the previous owner had upgraded the turbo to a ball bearing unit. I have no idea what the HP rating is as the P/O is dead and his widow is selling the unit. Also, there were no other gauges except the factory units. Other than initial start up it was quiet with a tad bit of "diesel rattle" on up shifting. The transmission felt solid and went into O/D as it should: about 45mph, and it shifted without hesitation. It is not "squishy" like my buddy's '96 F250. It stops in a straight line, and passing cars at 55 to 75 is child's play. It has 3:73s and cruises around 2000 revs at highway speeds.
The interior was "clean as a whistle" with only a few scratches in the driver's side, and the seats didn't have the usual "beat down" look. Why would an '01 have a manually adjusted lumbar support when the 96's had a push button? Anyway, the carpeting, door panels and glass are all good condition, and the P/O even had a shoe box full of old oil receipts and parts as he'd done most of the maintenance himself. A trip to the Ford garage for new front brakes and turned rotors lead to the discovery that no warranty work had ever been done to this truck, so near as I can tell the P/O had 7 trouble-free years!
Here's the rub -since it was originally a Canadian truck, the title shows that the mileage has been changed. IIRC, I thought there was a certificate that came with said adjustment, and that the "adjuster" had to be licensed. I don't suspect the mileage is wrong since everything else in the trucks looks like a 70,000 truck should, but I do wonder about the book value. I would hate to jump into something that's automatically worth 30% less than it should be, am I over thinking this?
Thanx in advance...
Old Mar 29, 2008 | 09:55 AM
F350-6's Avatar
F350-6
I'd contact DP-Tuner and see if they can tell you when their unit was sold for that truck. Also an oasis report might give you a better idea about the odometer. There's a thread in the 6.0 section where you can post the VIN and someone will tell you what the OASIS says.
The only thing I would look into is how to change the display from KM to miles. If you disconnect your batteries your CAN truck may try and revert back to KM. It also sounds like investing in some guages would be a good idea with the DP & upgraded turbo.
Old Mar 29, 2008 | 10:06 AM
PaysonPSD's Avatar
PaysonPSD
My 99 was built in KY for export to Canada. It has a Canadian door sticker. And like Jason said DRL.
Old Mar 29, 2008 | 10:39 AM
69-highboy's Avatar
69-highboy
This truck has the old fashioned odometer, not the LED type, so it appears to me that the entire unit has been changed. If so they did a good job as there wasn't a rattle in it. In fact my only complaint is that it take 40 acres to turn the truck around.
I didn't get the VIN because I was running out of daylight on the test drive, anyhow, I'll see the guy sometime today if all goes according to plan. I'd like to get the truck, but need a 1ton like I need a root canal! Yes the DP without gauges does concern me, and I'd like to find a stock rig, but this rig was owned by a 65 year old man, so I don't believe it was mistreated. As I understand it, he and the MRS used it to tow a 24' travel trailer, otherwise it sat in the garage.
My plan has always been to find a good F250, but it seems no such animal exists here as everything I've seen is either overpriced, or needs more work than I'm willing to put in it. I've been around the 6.9 & 7.3 for years and know them fairly well, but I also know that around 250,000 miles the bodies starts to fall apart -and therein lies the reason I'm looking for something newer.
I pull an 18" travel trailer, and on occasion a 4 horse trailer during hunting season. Cover you keyboard so you don't spit coffee everywhere, but I've pulled this stuff with my V-6 Toyota -it just doesn't have the weight, brakes, mirrors, or cojones to be a good highway rig when so loaded. The old '69 could do it, but it's really a hay truck that's seen her better days: no P/S, no P/B, no nothing, just a cab and a box bolted to a V-8.
Thanx for your service,
Semper Fi
zerfetzen
114
Jul 28, 2022 03:38 AM
grandpa.e
Feb 14, 2014 11:12 AM
montana_highboy
114
Jul 11, 2013 12:18 PM
WyoCobra
May 2, 2011 09:51 AM
fatdan460
Feb 12, 2011 09:30 AM
