tranny fluid
Old Mar 23, 2008 | 04:49 PM
pk8950's Avatar
pk8950
tranny fluid
I'm drawing a blank.What fluid goes in a c6 tranny?
Is it type f
Thanks paul
Old Mar 23, 2008 | 05:34 PM
Mil1ion's Avatar
Mil1ion
Which year ?
Usually Dexron II,III, IV, Mercon.
Only one year states it takes Type F.
From the 1979 Manual.
Old Mar 23, 2008 | 07:50 PM
tbear853's Avatar
tbear853
CJ or CobraJet Fluid as I've heard it called, or something compatible (read label)... .
Not Type F.
'77 F150
Old Mar 24, 2008 | 07:00 PM
pk8950's Avatar
pk8950
How do I find out what yaer the tranny is?
Thank god I didn't just buy the type F
Thanks for the help
Paul
Old Mar 24, 2008 | 08:55 PM
monsterbaby's Avatar
monsterbaby
Not Type F.
'77 F150
HUH? no such thing. CJ is an API rating for diesel rated motor oil, NOT trans fluid.
Basically you can use Dextron II, or III, mercon or a synthetic if you so desire on a new rebuild (I wouldn't on a used trans unless you know it's a fairly new rebuild) Even the ones that do call for Type F can use the Dextron/mercon fluids especially if they have ever been rebuilt.
Old Mar 24, 2008 | 10:23 PM
crescentwrencher's Avatar
crescentwrencher
so would dex II work for a 75 c6?
Old Mar 24, 2008 | 10:51 PM
fdude64's Avatar
fdude64
i sure hope so cause thats what i been using in mine but have no idea what year it is
Old Mar 25, 2008 | 06:10 AM
pk8950's Avatar
pk8950
I have no Idea if it been rebuilt or not. I know it was put in the truck about 6 years ago by the previous owner.
Old Mar 25, 2008 | 07:18 AM
brownfoot's Avatar
brownfoot
read the dipstick, my 76 says "type F"
most newer use Dexron
Old Mar 25, 2008 | 07:41 PM
pk8950's Avatar
pk8950
dip stick reads ESP-M2C138-CJ. Whats that mean?
Thanks
Old Mar 25, 2008 | 08:26 PM
brownfoot's Avatar
brownfoot
see the chart from Million,,,,,,,,,,,,,dexron type, Not type F
Old Mar 25, 2008 | 08:33 PM
tbear853's Avatar
tbear853
Thanks
That's the stuff I was talking about, it's the only one that ends with CJ and a fellow I know been building transkissions for years calls it "Cobra Jet fluid". It's an easy way to remember it, and it's what I look for on the label on back in fine print as in compatible with.
Old Mar 25, 2008 | 09:44 PM
pk8950's Avatar
pk8950
Thanks for the help
Old Mar 25, 2008 | 10:27 PM
Redtires019's Avatar
Redtires019
I have always been told that "Type F" had an addative in it for the old abestos clutches Ford use to use in their transmission. We no longer use Abestos so when one is rebuilt and the old clutches are replaced you should no longer put Type F in it.
Has anyone ever heard of this??
Old Mar 25, 2008 | 11:33 PM
brentleedragon's Avatar
brentleedragon
yeah thats what a guy told me when he was rebuilding my friends tranny that used type f. he said that after the rebuild he should no longer use it because it will have no clutches and stuff like that, and type f is no longer needed.
