cab change?
Old Mar 23, 2008 | 04:35 PM
wyodevildog's Avatar
wyodevildog
cab change?
does anybody know if a 78 f-350 cab will fit a 77 f-150 and if so are there any mods that have to be done? fhey are both standard trannys and both are single cabs
Old Mar 23, 2008 | 04:37 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Yep, 73-79 cabs will all interchange. Only real difference in them are wether you have the incab tank or frame gas tank.
Old Mar 23, 2008 | 05:49 PM
76f350spercamprspeal's Avatar
Was there a certain year they put the "Incab" tank? I had a 1977 Ford F-350 Factory Stakebed! ??????This truck had a 460,3 tanks,one in cab,2 in bed!
Old Mar 23, 2008 | 06:07 PM
cjstang32's Avatar
cjstang32
The F-350's frame was most likely 34" front to back while the F-150 flares out to 37.5" under the cab. What this means is the rear mount points are different. You'll probably have to drill some different holes but other than that everything else should be the same.
Old Mar 23, 2008 | 09:46 PM
wyodevildog
thank you guys for the help. if you know of anybody looking for old fords they are pretty cheep here in northern wyoming . i have just bought a 77 f-150 4x4,71 f-250 4x4 and a 78 f-350 daully 2x4 all for 1,000 dallars and all run good very little rust and thare are many more around
frigerator
Feb 19, 2011 03:33 PM
Growl60
Nov 2, 2009 05:32 AM
mountainman101
2009 - 2014 F150
Mar 13, 2009 06:16 PM
pfcnelson
Aug 14, 2008 06:09 PM
