Sponsored by: Real Truck
Cruise Control??
Old Mar 23, 2008 | 10:11 AM
Mucks's Avatar
Mucks
Cruise Control??
Hey,
On My 2000 F-250 my cruise seems to stopped working. i have a SP Performance turbo brake installed which uses the ON OFF cruise switch to be turned off and on, that still works so i believe the ON, Off part is fine, any ideas??
Old Mar 23, 2008 | 10:25 AM
OverEngineer's Avatar
OverEngineer
Cruise Control on my 2001 has been a problem since I took delivery of the truck. It seems to have a mind of it's own. Sometimes it works (IE it turns on at all) and sometimes it will not. I have put up with it, just like the fact that the passenger door lock has never worked. If you find a cure or weak component, please let me know
Old Mar 23, 2008 | 11:07 AM
F350-6's Avatar
F350-6
What motor do you have in your truck? The diagnosis is different for gas vs. diesel.
Old Mar 23, 2008 | 11:33 AM
F350-6's Avatar
F350-6
OverEngineer, I hope you've had the cruise control recall done on your V10. It has to do with trucks catching fire.
Here's a self test you can do to isolate your problem. Let us know how many flashes you get and we'll tell you where to go from there.
File Type: pdf
Old Mar 23, 2008 | 11:54 AM
Mucks's Avatar
Mucks
Hey, the trucks powerd buy a 7.3 PSD.W/6spd standerd
Old Mar 23, 2008 | 11:59 AM
F350-6's Avatar
F350-6
That reminds me mine acted up earlier this week. For the 7.3 you have to have a scanner and run a switch test for diagnostics. If you post your location maybe someone lives close by that has a PSD capable scanner.
My problem happens to be the clutch pedal position switch. I need to go play with that again today.
Old Mar 23, 2008 | 12:03 PM
Mucks's Avatar
Mucks
hey, thanks. Im up in maine about 30 miles from portland. would a ford dealer have a scanner? i know a few mechanics there from the local mud runs.
Old Mar 23, 2008 | 12:28 PM
F350-6's Avatar
F350-6
Yes the Ford dealer has the correct scanner, but they usually charge the most in town to use it. I just went and looked and I've got a broken spring inside my CPP sensor.
If your buddies can tell you what's wrong we should be able to help you fix it.
Old Mar 23, 2008 | 06:30 PM
OverEngineer
Good Stuff and Reputation Points
That file was a gold mine. Thank you so much. I am going to do the self test and see what happens. It's nice when a Leather Neck can help out a Swab Jocky. I'm tapping your rep points for the file. Thanks!
Oh! I did get the fuse link put in a couple of years ago.
Old Mar 23, 2008 | 06:34 PM
F350-6's Avatar
F350-6
Well if I had know you were a swabbie.....
Let me know which chart you need based on your flashes and I'll post the steps to take from there.
Edit: Thanks for the rep points.
Old Mar 29, 2008 | 10:59 AM
OverEngineer
Stand by for test results
here we go - hope it works with a manual
