Grille
Old Mar 23, 2008 | 07:42 AM
dovepro's Avatar
dovepro
Grille
Have a 77 F100 Ranger XLT do not like the round lites would like to have square
are the 77 & 78 interchangeable.
Old Mar 23, 2008 | 07:50 AM
rsalter66's Avatar
rsalter66
Are you talking about the whole grille assembly?
if so yes, just swap out all of it
I don't know if you could just swap out the headlight buckets and surrounds? but I do not think so
Old Mar 23, 2008 | 07:57 AM
dovepro's Avatar
dovepro
Yes! Son does not like the 77 grille. This will make him happy Thanks...
Old Mar 23, 2008 | 08:13 AM
tankrsc's Avatar
tankrsc
Yes if you swap out the whole thing. Get it all including the bucket behind the grille that is bolted to the radiator support. You will have to drill a few hole in your support to mount them because the '78-'79 headlights set higher. It is an easy swap I did it on my '77 that for some reason came with the '78 grille. You have to loosen the inner fender wells and you may or may not have to remove the front bumper, I had to remove mine but a buddy of mine that I gave my old grille didn't have to remove his to get it on.
Old Mar 23, 2008 | 08:23 AM
rsalter66's Avatar
rsalter66
To bad we are so far apart
I would trade ya, but not worth the shipping it would take to NY
I love the older grille with round lights
Good luck
Old Mar 23, 2008 | 11:56 AM
75F350's Avatar
75F350
I just perfomed this on my 74 truck. It was as easy as pie. I also changed the bumper so obviously the bumper had to be removed.
Only two holes have to be drilled into the radiator support. Your older round headlight bucket doe not bolt up quite the same, and the square units have two additional holes in the lower portion per light. Here are a few picks, you can see where the holes have to be changed.
You will also need the bulb socket, and as much of the wiring as you can get. The factory harness falls a little short to reach the new turn signal / parking lamp location.
Other than that, a real easy swap.
http://s292.photobucket.com/albums/m...t=HPIM0833.jpg
75
Old Mar 29, 2008 | 07:13 PM
fordophile's Avatar
fordophile
are your 74 parts in ok condition? my 74 has had a 76-77 grille swapped in, and i want to go back to the 73-75
Old Mar 29, 2008 | 07:32 PM
75F350's Avatar
75F350
You talkin to me?
I just updated my photobucket http://s292.photobucket.com/albums/m...t=HPIM0824.jpg
I took a pic of the old grille so you can see the condition. It is faded, and will not shine well unless the anodized finish is removed, and the aluminum is polished. I have the headlights, buckets, turn signals, bulbs, and grille inserts.
You will notice two small dents at the bottom of the grille on both ends. This was from a little contact with the bumper and some large rocks, but is pretty well concealed by the bumper. Inserts are in good shape and not too brittle. Never been painted either. Everything is all original.
Pm me if you have any questions or might be able to use it for your project. I will probably never go back to this grille, besides, I have two other complete ones.
I reside in So Ca, so shipping might be a little bit of an issue, but this stuff is light.
75
Old Mar 29, 2008 | 08:08 PM
fordophile's Avatar
fordophile
well, also just a little unwieldy for shipping...not looking for a necessarily perfect shell anyway, as truck is a driver, so that should be fine....definitely looking for the inserts....will not need buckets, signals, etc, since those are original and fine on mine...so, whatever you can shoot me to 61529 on shell and inserts....do you still have the bumper?
Old Mar 29, 2008 | 08:43 PM
75F350's Avatar
75F350
Yes, I do have a bumper, but it has a square hole cut in it behind the license plate, and if you recall the big rock incident, it has quite a bit of rock rash on the outside edges. I get into rather large rocks. Many of them large enough to have hit the light bar that was mounted on top of the front bumper.
Yes, I have the bumper, but it is not a show quality piece at all.
I will PM you with contact info, and we can work something out on shipping and such.
75
Old Mar 29, 2008 | 08:58 PM
75F350's Avatar
75F350
fordophile:
I wroye you a crazy long PM, but it apprears that with your short post count you may not have this available to you just yet.
No biggie, e-mail me and we can discuss specifics, and perhaps any additional items you may be looking for.
erendon1@verizon.net
