Sponsored by: Auxito
Vibration at 55 mph
Old Mar 22, 2008 | 11:00 PM
f15097's Avatar
f15097
Vibration at 55 mph
I have a 1997 F150 4wd truck with 92000 miles on it. It has an automatic transmission with a 4.6. I do not have a check engine light nor does the truck run hot. The last two weeks I have noticed a vibration that starts around 49 mph and gets worse until about 60mph and than it isn't as noticable. I just replaced the UV joints. It hasn't gone away. I have also noticed an oil leek from the rear seal that seems to have started at the same time the vibration started. If anyone has some suggestions on what or where to look to solve the problem I would appreciate it.
Old Mar 23, 2008 | 09:13 AM
tampa898's Avatar
tampa898
How is the rubber on the truck?, did you lose a balancing weight perhaps. How about the Universal joints? Look for the easy stuff first.
Old Mar 25, 2008 | 06:18 AM
f15097's Avatar
f15097
I really believe it isn't a weight on a tire causing the vibration. It feels as if it is coming from the center of the truck the drive shaft or transmission. The oil leak appears to be the rear seal area. It is not transmission fluid. The vibration starts at about 40 mph and grows worse until it gets to 55mph after that it subsides some. I feel that the oil leak is related to the problem.
Old Mar 28, 2008 | 06:20 PM
f15097's Avatar
f15097
follow up Vibration 55mph
Could a broken engine mount cause vibration in the drive shaft area? I have a vibration at idle as well as 55mph.
Old Mar 28, 2008 | 07:57 PM
Bobby82490's Avatar
Bobby82490
Was it doing it before replacing the ujoints?
Old Mar 28, 2008 | 08:00 PM
steve(ill)'s Avatar
steve(ill)
when was the last time you changed the transmission oil? look up converter shutter.
mclarengts
May 20, 2016 02:23 PM
pittdog1977
Jun 8, 2014 09:56 AM
whf
Jul 27, 2010 12:11 PM
KTim
2004 - 2008 F150
Sep 5, 2007 01:55 PM
mjs
Jun 21, 2005 09:46 AM
