Better mileage?
Old Mar 22, 2008 | 04:13 PM
EMc's Avatar
EMc
Better mileage?
I have a 1993 with an after-market Banks Turbo. I get approx. 12 mpg, unloaded. Should I expect better mpg?
Old Mar 22, 2008 | 05:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle
EMc,
Welcome to FTE and the IDI diesel forum.
Old Mar 22, 2008 | 07:28 PM
dakotajeep's Avatar
dakotajeep
put more info about your truck in your sig so others can give pertinent info....
welcome!
Thad
Old Mar 24, 2008 | 06:28 PM
EMc's Avatar
EMc
'93 F250, 7.3L, auto trans, ext. cab, long bed
It has an after-market Banks tubo. I get about 12 mpg, unloaded. Can I expect any better mpg?
Old Mar 24, 2008 | 06:47 PM
David85's Avatar
David85
His sig will not show up until he has 25 posts.
EMc, I think you can expect more from that truck.
What is your axle ratio?
What conditions are you driving in? (average speed, hills, traffic, wind, weight of foot)
Are there any other problems, such as smoke, hard starting, or lack of power?
How long have you had the truck?
Has it always done this?
Old Mar 24, 2008 | 10:41 PM
dakotajeep's Avatar
dakotajeep
Thats nice.....lol
Old Mar 25, 2008 | 05:02 PM
Dave Sponaugle
EMc'
What RPM are you turning at say 60 MPH?
What RPM do you normally cruise at?
Is most of your driving open road or city type driving?
And last question for now, are you in flat country or mountains?
Old Mar 27, 2008 | 06:59 PM
EMc's Avatar
EMc
Approx. 1800 rpm's at 60 mph. I usually drive about 65mph. The terrain is mostly flat. Most of the driving is open road.
Old Mar 27, 2008 | 09:20 PM
Dave Sponaugle
Most of my tire diameters are for mud tires, which are usually a bit larger.
1800 RPM with a ZF 5 in overdrive on 235/85-16 tires should be running about 63 MPH with 3.55 gears.
12 MPG sounds a little low with that setup.
Is the truck 4x4 or a dually?
Do you still have the stock bed on it?
A little more info about the truck would help with possible problems.
Like a 4x4 sits up higher, catches more wind and weighs more with more moving parts.
So 4x4 MPG is usually a bit lower that a 2 wheel drive truck will see.
How many miles on the engine?
Do you know if the IP or injectors have been replaced?
Do you see much black smoke out the exhaust?
Old Mar 27, 2008 | 09:45 PM
David85's Avatar
David85
Something is wrong, those are the ideal conditions for getting good economy.
Old Mar 27, 2008 | 10:18 PM
George D.'s Avatar
George D.
Try realy working the truck hard for a few days long trips up big hills and realy get into the throtle. I just went from Vegas to Phoenix and back last week end and now I have more fule come thursday than normal with more millage than normal for a week. Most of my diving is city 10 miles to work ten miles back. then going to the store bank and things like that I rarely hit the highway unless I'm gong out of town because of where I live. Short trips in town are hard on diesels and will bring millage down if you don't work the truck once in a while.
This is assuming there isn't something wrong like excesive smoke or ebrake sticking. What sise tires are you running are they properly inflated? Is your truck running hot enough?
