What Scott said, I just remembered my mix-chamber was removed when I did the in-tank and pre-pump mods. I use the in-line filter from NAPA I think #3003.
[QUOTE=sflem849]I think this was already covered, but there are two "filters" in the tank of a pickup. The first is the gross particle screen on the pickup foot and the second is the mixing chamber. They have some rather fine screens in there.
I would bet the air through the fuel lines into the tank has cleared up the screens enough to make it better, but not perfect.
Here is the link to the intake directions ITP provides. They have some pics in the directions that will help you see what I am talking about. If you take the mixing chamber out you have to put something in line to protect the fuel pump/operate as a gross decon of the fuel. I just used a cheap inline filter from NAPA. That is what the guys from Diesel Innovation do. (Dennis used to as well, but he has upgraded to a better (finer than the stock setup) filter)(quote)
Yes, thats what I wanted to hear, thats what I believe is causing my poor performance and miss. What method was used to install an inline filter to those new fuel lines with the quick connects and when removing the mixing chamber is it just replaced with a hose line to lay at the tanks bottom?
No Roger, you need some tubing the same dia. preferably s.s. and some fuel line that's diesel rated to run from the tank to the pump. Do a search on the in-tank mod. Look at the top of the page I think there's a link for common mods.
Thats what I plan to modify now. A ford guy I just spoke to advised against it but it was a ford design that proved wrong. Does this technique prolong your injection filter life also? Do you know how they spliced into the fuel line and what they used to alter the mix chamber assembly ?
Just use this setup for your instruction list. http://guzzle.rbmicro.com/hutch.html
I would just run cheap NAPA inline filters until I had things cleaned up. I have less than $40 in my intank setup.
I used a hybrid of the Guzzle, ITP, and DI setups. I used the existing hard line between the pump and tank and just ran rubber line between the two. This requires more hose clamps and connections, but I think it is prettier.
Here is a quote on the filter ITP used to use.
Originally Posted by Izzy351
More details from FleetFilter:
Part Number: 33007
UPC Number: 765809330078
Principal Application: Mercedes-Benz Cars (89-95) - 5/16 in-line fuel filter - can be used wth gas or diesel
Read the Guzzle link. You will figure out how it all works after that.
Why would he suggest against it??? I can only think of one reason and that is bc you eliminate the intank filter AND you do replace it OUT OF THE TANK...WHERE YOU CAN SERVICE IT!
It will help inj life bc you are not hammering as much air through them.
You splice into the hard line with 5/16 (?) fuel line and hose clamps. I just put my filter right before the pump.
You use brake line to get rid of the mixing chamber. Simple!
i also cant see why, even if the fuel ate your tank, the truck would die after 45 minutes of driving? what did the inside of your tank look like? and why was the fuel pump condemed? the diag methods arent making much sense here
On the E series tank(as far as I know) the inside tank has a painted grey safety coating. The new low sulfer diesel bubbles this coating from the metal and causes the paint chips to congregate at the sump screen . When enough chips accumulate on the screen a blockage occurs and the engine stumbles and dies. After being off for a while they fall back to the bottom of the tank and the truck starts as if nothing ever happened. My fuel pump I believe burned out from the restriced suction because when I disconnected the line from the pump and turned the key it had no suction. I rather be safe than sorry anyway, breakdowns and down time for a work truck is never good or finiacally beneficial.
Thank you everybody for the great input on the fuel mixing chamber. I plan on retrofitting it at my earliest convenience. I hope this is the cause of my trucks poor performance and fuel milage (10 mpg) at total vehicle wieght 0f 7875.
What kind of tank did you replace it with? Will it do the same thing? If you think you still have debris in the tank that is sucking up to the pickup screen, you my get by just draining the tank to clear the junk out. It is a pity that you didn't know to do the intank mods while you were in the process of changing tanks.
I bought a new aftermarket uncoated unit. The shop is giving me a 1/2 price credit on it when I buy the original back with the new red coating inside. I plan on reinstalling the old refurbished tank hopefully later this week. Thank you guys for the mod info or I'd be back at square one with low fuel output. I just really hope this is the cause of my engines poor performance.
As odd as it sounds, Ford put out a broadcast message to dealers on this problem. That's as far as it has gone. No TSB as of yet. Here's the service message Ford has sent to dealers on this problem:
Lack of Power, Trucks with Steel Tanks:
Some trucks may have a lack of power due to low fuel pressure from a plugged fuel filter or in-tank pickup tube, or restricted fuel lines. This could be caused by the steel tank lining becoming de-laminated/flaking off. If this occurs, the tank will need to be replaced, along with the plugged components. Be aware that using biodiesel with more than 5% concentration (B5) may cause this to happen. The replacement tanks do have a more resistant coating to help prevent this occurance, however Ford still recommends using no higher than B5 biodiesel. Broadcast Message 6865, 7103.
So it isn't the ULSD, it is the Bio. There is a big different between those two.
I was going to say you should really do the intanks when you do the new tank. But now that I read the "notice" maybe you should not??? The part about clogged FUEL LINE(?!?!?) scares me a bit. I think I would want the filter as close to the pickup as possible in this case.
Oops, rethought. what does it matter!?! When it finally clogs your mixing chamber you will have to buy a whole new sending unit anyway. They do not sell components of the system. My newest thought is still do them. That way you will have a filter right outside the tank.
Austin
The scary part to this is I've been filling up at the truck stops with that greenish looking ulsd all this time. Thank you EPA.
So far it seems Ford isn't sure what the true cause is. They seem to think it's the Bio, but the verdict is yet to come in for sure. As usual it seems, more will be revealed.
