Gutting Cats concern
Old Mar 21, 2008 | 02:40 PM
FordF350Baby's Avatar
FordF350Baby
I was going to try and gut my cats myself, but when I crawled under there i realised one of the cats in the true dual has an o2 sensor in them, so I didnt want to mess around with that. How can I overcome this, is there a safe to go about gutting the cat without screwing up that O2 sensor?
Old Mar 21, 2008 | 03:36 PM
73f100shortbed's Avatar
73f100shortbed
Remove the sensor. 22mm wrench should be the size. They also sell o2 sensor sockets. Can be found at autoparts stores. Are you concerned about hitting it while gutting the cats?
Old Mar 21, 2008 | 05:51 PM
dkf's Avatar
dkf
How many sensors do you have on your 95'? 3 O2 sensors? Where on the cat is the sensor located, center or rear of the converter?
Old Mar 21, 2008 | 09:15 PM
FordF350Baby
Yes, I was concerned how to remove it from the cat so I could take the cat off, and didnt want to ruin the sensor. I have 2 o2 Sensors, one of them is inside each of the pipes in the true dual. I havent gotten a chance to see where exactly the 02 sensors is positioned, but i believe its right in the middle.
Old Mar 21, 2008 | 10:20 PM
73f100shortbed
95% of the time it will unscrew right out. 22mm wrench and try. Should be ok with that.
Old Mar 21, 2008 | 10:53 PM
FordF350Baby
Awsum, now regarding getting them cats out of there, there currently welded on, I am a little sad to go and cut them out of there, and then have to clamp them in there, and then prob have someone weld them at some point, but i dont want them to see that I gutted them, so I gotta be careful, but what do you guys suggest to "gut" them with? A dremel or something? I also have considered what some of you have suggested and that was to install a piece of pipe inside of the cats so it wont distrupt exhaust flow, but my question is, wont this affect that "hollow tin can" noise I am looking for by doing this in the first place? I am not doing it for power, I realize that these hi flow cats are already free flowing, but i want it to be louder, so cant I just leave them they way they are after i gut them. I mean, its not like the exhaust isnt getting disturbed right now having to go thru them now, so what would be the differnece once the material was gone?
Old Mar 22, 2008 | 02:20 PM
73f100shortbed
A hammer and a big screwdriver or pry bar should do the trick. Not sure why you want a hollow tin can noise but putting the pipe in the cat is just making a straight pipe look like a cat. So it would be the same as cutting your cat out and putting a piece of pipe. If it is welded on cut the weld with a cutoff wheel so you can slip it off the pipe and then re-clamp on. If they are clamped and someone re-welds them they won't know its gutted unless they take it off. You could always just leave it clamped too. It won't matter much.
Old Mar 22, 2008 | 03:23 PM
kens64's Avatar
kens64
LOL sure, use a dremel. This has been discussed 10,000 times before. Clicking on the SEARCH button would help a ton here.
Its not the same for the exhaust to flow through a healthy cat, and to suddenly run into a hollow chamber that will cool the gasses therefore slowing them, and cause tons of turbulance. This has been discussed 10,000 times before. Clicking on the SEARCH button would help a ton here.
What do you consider a "hollow tin can" noise? You do realise gutting the cats will usually cause a more harsh tone and more popping and other normally undesirable noises. You were told that in another thread. If you are talking about the old muscle car "pinging" sound (which I think is very cool) dont even try it. You dont have a muscle car engine. Big difference.
Old Mar 22, 2008 | 05:43 PM
dkf's Avatar
dkf
Honestly I would just leave the cats alone. Especially since you have O2s screwed into your cats.
If you want your exhaust to be louder just exit the pipes in front of the rear wheels that will make it louder. I guarentee do that will make the truck louder.
Old Mar 22, 2008 | 10:12 PM
FordF350Baby
Hmm...Yeah, I suppose not ever thinking about my exhaust system again would help put all of this to rest. I get side tracked to often, and want my vehicle to be things its not and I just need to except the certain things that it is. I honestly dont ever want to touch this exhaust system again, its way to stressful for me to continue contimplating all the various possibilites of sound, because at the end of the day, exhaust is exhaust, and I have a nice system right now, and theres no sense in trying to kepe *****ing with it. Thanks guys for your input.
Old Mar 22, 2008 | 10:56 PM
73f100shortbed
If you like what you got keep it.
Old Mar 23, 2008 | 10:35 AM
Bear River's Avatar
Bear River
Former ******
Well, and removing the cats might make it more than louder, it might make it poppy and raspy. If you like it that way, thats fine, but myself, I want a smoother tone. Bring the tips out in front of the rear tires and you should get louder while retaining your current tone.
Old Mar 24, 2008 | 09:17 AM
FordF350Baby
that seems to be the best compromise
