yes it is I like the way it works but i know nothing about it
It (the 1704) may not be compatible with the flash level on your truck. If you are the original owner of the tuner, and have a receipt to prove it, you can sent it in for a firmware upgrade. If you bought it second-hand, then you have something to sell on eBay. You need to be careful when buying used tuners, if that's what you did...
I bought it for my 04 4x4 sdc 6.0 then I found and 03 6.0 and had to have it to so I called superchips and sent them my vin# they reprogramed it and sent it back worked fine i thought? then i had to have a new HPOP AND just noticed it the other day when I passed some slow trafic could it be the tranni.
If ford re-flashed your truck while it was in for the HPOP, perhaps that could have caused a significant enough to change to require yet another superchips factory reprogramming. Check into it...
