Air filter removal
Old Mar 21, 2008 | 02:02 PM
HowieE's Avatar
HowieE
Air filter removal
What's the trick on getting the air filter out? I can release the 4 clips at the top and see how the rear filter housing is in a slots at the bottom but can't seam to get enough rearward movement to lift the filter out.
Old Mar 22, 2008 | 06:05 AM
kawajockie's Avatar
kawajockie
I have a 7.3, so not sure it is the same or not.....
There are also bolts in the bottom of the air box.
Make sure you remove the cover for the driver side battery, then it just lifts out.
Don't forget to remove your air box temp sensor!
Old Mar 22, 2008 | 09:14 AM
HowieE's Avatar
HowieE
I should have mentioned I have a 2004 6.0
Old Mar 22, 2008 | 09:21 AM
kawajockie's Avatar
kawajockie
Sorry,
I thought the 6.0L had a good factory air filter set up. What are you replacing it with?
Old Mar 22, 2008 | 09:34 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Check out the link
http://home.austin.rr.com/sbv1/Proce...irFilterRR.htm
Old Mar 22, 2008 | 01:09 PM
HowieE's Avatar
HowieE
Originally Posted by weekendwarriorfsw32
Now that is some information. My hat is off to you for suppling it and to whom ever went to the trouble to create it.
As I recall the instructions for the SATs were not that hard.
Thanks Again
xtal_01
Dec 1, 2016 12:03 PM
Wyowanderer
Sep 20, 2016 09:19 PM
winggs
1947 and Older Ford Trucks
May 4, 2016 08:03 PM
doczenith1
6.7L Power Stroke Diesel
Jun 20, 2014 10:15 PM
GeorgiaBoy17
17
Feb 8, 2014 09:49 AM
