lost throttle response from 351W
Old Mar 21, 2008 | 12:42 PM
jbirdsvt's Avatar
jbirdsvt
i had to replace the fuel pump and went with a holley electric pump. i'm showing around 5.5psi of fuel pressure at idle. if i ease into the throttle, it's fine, but if i stomp it, it just boggs and will even cut off. what gives?!
Old Mar 21, 2008 | 01:00 PM
Beanscoot's Avatar
Beanscoot
Maybe you've got a clogged filter, or a bit of crud in the carburetor which is partly clogging a main jet.
Are you able to check the fuel pressure reading when the engine powers out?
Why did you use an electric fuel pump?
Old Mar 21, 2008 | 04:08 PM
jbirdsvt's Avatar
jbirdsvt
i went with an electric pump because it was easier than replacing the eccentric and the mechanical pump. i also put on an electric fan at the same time. i know it's not a clogged filter because i replaced that too when i replaced everything else. i've tried it with no filter at all and it's the same thing.
Old Mar 21, 2008 | 09:55 PM
doug1222556's Avatar
doug1222556
Maybe you need to do a flow test on that pump. Could be building pressure but just peeing a little stream, and its a faulty pump, with a built in clog.
Old Mar 24, 2008 | 12:28 PM
roothog460's Avatar
roothog460
Hey guys, I have a 79 100 with a 302/ 2 barrel, and it does the same thing. I have a new stock manual pump, and i have cleaned the carb and replaced the filter. It idles like a champ, but if i don't pedal it, it cuts off when I try to pull off. Will weak ignition or bad plugs cause this? I have the duraspark POS ignition system with vacuum advance distributor.
Old Mar 24, 2008 | 12:38 PM
roothog460's Avatar
roothog460
Hey jbird, check out the response to roothog460's post
Jebs
Modular V8 (4.6L, 5.4L)
Jan 16, 2015 06:28 AM
Superred2
Dec 12, 2010 07:50 AM
terryq
2004 - 2008 F150
Oct 31, 2010 07:41 PM
FARM69
22
Apr 8, 2010 06:06 AM
JBronco
1978 - 1996 Big Bronco
Aug 7, 2006 09:24 PM
