Modular V10 (6.8l)
Rough Idle?
Old Mar 21, 2008 | 04:01 AM
Bracen's Avatar
Bracen
Rough Idle?
I've noticed lately that my idle has seemed to be really rough. The tach stays steady at about 775ish but you can feel it, almost like theres a miss/hesitation, Sometimes it feels like a cylinder forgets to fire. The plugs we changed about 25,000 ago. I pulles all the COP and checked to make sure thatthere was no moisture inside. When I'm driving down the street thing seem good enige pulls good and no hesitation at all, it only seems to be an idle issue. No check engine light on.
Any ideas???
Old Mar 21, 2008 | 08:04 AM
bigblock_drock's Avatar
bigblock_drock
probably try cleaning the MAF.
Old Apr 6, 2008 | 07:59 PM
fordman1399's Avatar
fordman1399
i have the same problem...cant seem to hunt it down yet...i bought a new maf sensor today for $100.00 and no difference at all? the dealer couldnt find it either...
Old Apr 6, 2008 | 09:56 PM
biz4two's Avatar
biz4two
Arrow
You guys might want to look into cleaning or replacing the IAC (Idle Air Control). They build up with carbon...and can affect the idle.
Take a look at my gallery...I have a step-by-step with pics.
https://www.ford-trucks.com/user_gal...&albumid=22274
Good luck...
biz
Old Apr 7, 2008 | 12:22 AM
auto's Avatar
auto
May have a vacuum leak. The O2 voltage will stay sued lean and fuel trim positive at idle. Best way to find the leak would be with use of a smoke machine. Less conventional way would to use propane or carb cleaner around intake and piping and watch for an rpm change.
