another tank question
Old Mar 20, 2008 | 09:14 PM
Danger_Dave's Avatar
Danger_Dave
well I have gas tanks galore. the stock one behind the seat. and then 2 aftermarket humungous ones under the bed. i have no idea if they work or not but i did a visual inspection underneath and everything appears to be hooked up and hose clamps and whatnot are all nice and tight and dialed in. i tried shining a flashlight inside to see in there but that didnt work out, lol. maybe i need a match!
i am LAZY. and i have no idea if they are all rusted and nasty on the inside or not. is it totally necessary to take them off and rinse them out? or can i get away with some other easier method and still leave them on the truck?
i am making a 3400 mile trip here pretty soon and these things are seriously gonna come in handy.
Old Mar 20, 2008 | 09:44 PM
blue68f100's Avatar
blue68f100
Install a clear lens inline filter coming out of the tank, add 5 gal of gas and run off of one. You will find out what condition it's in, either by plugging a filter or leaking on the pavement. At least with this way you will have a good tank to switch to when the filter plugs up. Do one at a time. If full of rust you will need to drop clean and seal/coat.
Old Mar 21, 2008 | 06:35 AM
OneManArmy's Avatar
OneManArmy
Quite being a lazy little bitch Zwarty!!! Take them off and scrub with a toothbrush. Lol...
When you making your 3400 mile trip?
Old Mar 21, 2008 | 08:47 AM
Freightrain's Avatar
Freightrain
Ya, like blue says....get a handful of plastic see thru filters and take with you. Install one for each tank and watch if they fill up with grit. Cheap and "easy" LOL!
My '64 Galaxie had issues with rust, it took a couple years and a few of those filters to finally get rid of all the rust. Car sat(outside) for a number of years previous to my purchase.
Old Mar 21, 2008 | 10:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford cars from 1961 thru 1979 and trucks with factory under bed auxillary tanks (1967/79) have a plastic meshed filter screen on the pickup tube: D1AZ-9A011-A / Sold by Ford and most parts stores.
The Galaxie gas tanks (1960/64) (except wagons) have been reproduced.
dearbornclassics.com / online catalog / page 164 / Part # GT60A
If you don't know about Dearborn Classics, you will be amazed when you get a catalog, and see what's now available.
You can order one over the phone, it's free: 800-252-7427.
btw: The big dummy has two 1963 Galaxies.
Old Mar 21, 2008 | 02:19 PM
Danger_Dave
brandon! me and gorilla joe are bouncin out in june but not without a wig splitting beer bonging peace disturbing extravaganza beforehand.
blue68, thanks i'll give that a shot, but i am confused about the leaking on the pavement, i understand about the clogging of the filter but what would cause leakage?
bill thanks, you split my wig every time! but i dont think they are stock ones, they are huge, must be 25 gallons and have a logo stamped on them but i am stuck out on this floating city at the moment
i guess i'll buy a case of filters and wing it
Old Mar 21, 2008 | 02:28 PM
NumberDummy
Floating City? Where are you located, on a CVN?
Old Mar 21, 2008 | 03:56 PM
Freightrain
Ya, seen the Dearborn catalog. Wow.
I'm in good shape now, as it's been 10 yrs without incident and the filter stays clean now.
Old Mar 21, 2008 | 09:42 PM
mikey92665's Avatar
mikey92665
easy way 2 clean a tank is ,...put a hand full of marbles&2gal. of gas in tank...shake well,get tired of shakin, rest then shake some more...pour gas&marbles out in clear jug. then u will know if u have rust in your tank or not.GOOD LUCK.
