Sponsored by: Kumho
brake clicking noise
Old Mar 20, 2008 | 06:36 PM
rhgibson's Avatar
rhgibson
I have a 96 ford f-350 with a powerstroke. When driving the brakes make a noise under the dash that is a clicking sound like a switch. I disconceted the abs unit and grounded the wire as instructed by a repair manual. The light flashed 16 times and the code was all ok. I have replaced the sensor in the rear end to see if this would help with the other problem of the speedometer bouncing. The brakes work fine but sometimes I get a hard pedal but they still work. Also it sometimes has a pedal that pluses like a warped rotor.
Old Mar 20, 2008 | 06:47 PM
scrapyardking's Avatar
scrapyardking
Sounds like the caliper is loose.
Old Mar 21, 2008 | 01:50 PM
chrono4's Avatar
chrono4
Are you sure it's coming from under the dash? If the noise stops when you apply the brakes, it's more than likely a missing anti-rattle clip on one of the calipers.
Old Mar 21, 2008 | 09:17 PM
winjoy's Avatar
winjoy
I have the same problem! Although we have replaced some of the pins or tried to use the old pins. This seems to work for a little while but the problem keeps comming back. Any other ideas that have worked?
Pigman54
Oct 31, 2014 12:37 PM
hiroller
Escape & Escape Hybrid
Aug 3, 2014 11:34 AM
RedBoat
1983 - 2012 Ranger & B-Series
Apr 26, 2006 06:36 PM
ckstrawser
Jan 1, 2003 12:06 AM
Steve90TTZ
Nov 8, 2001 07:00 AM
